seat questions
Old Aug 29, 2009 | 02:46 PM
EKing's Avatar
Default seat questions
I might be getting a 1991 civic hatch but the seats are messed up. So I was wondering what seats will just bolt right in or require the least amount of work to be put in I need to replace the front and back seats.
Thanks for the help.
Old Aug 29, 2009 | 07:27 PM
garageEF's Avatar
Default Re: seat questions
Least amount of work?
The only seats that are going to bolt right in are from a 90-91 civic.
88-89 civic are different as well as all years of CRX.
This is pretty trivial knowledge, check out the FAQ for info on pan swapping, etc.
Old Aug 29, 2009 | 11:12 PM
EKing's Avatar
By least amount of work i meant like no cutting the floor boards or anything like that. but thanks for the info. I just was wondering cause I used to have a 96 hatch and i know that you could put the Integra seats in my old hatch and i was wondering if the Integra seats could fit into the EF if i changed the seat rails, and if the rear seats could be put in. Thanks again
Old Aug 30, 2009 | 10:23 AM
garageEF's Avatar
Im not 100% sure whats involved with installing integra rear seats. i do know that the bench part is too narrow to completely fill the space, but looks decent if done right.
As for integra front seats, 90-93 DA seats fit with three bolts and slight modification to the rails. 94-01 DC seats im not sure about.
Like i said before do some research about seat pan swapping and you can get them installed correctly.
Old Aug 30, 2009 | 10:27 AM
EKing's Avatar
sweet thanks for the info
Old Aug 30, 2009 | 10:43 AM
ej1love's Avatar
you should have some options if you wanna swap rails or pans...
jdmdingdong
Sep 6, 2011 06:16 AM
Fullthrottle297
Jun 3, 2008 10:28 AM
Civic89stdB16
Feb 13, 2007 06:10 AM
uLTrAvTEc757
20
Oct 4, 2004 06:10 AM
mraudio13
Sep 18, 2002 06:07 PM
