asr brace with suspension technique sway bar???
i have a 98 Civic DX. everything bolts in. depending on what struts you have on you may or maynot have to move the bolt that goes into the bottom of the strut to the other side.
i'll try to take a pic but i already sprayed everything over in flat black.
ok let me refresh everything i say,when i install the rear suspension technique i have to drill couple holes for the swaybar to fit on ek subframe because it will not bolt right up to the original hole. now i want to know will it bolt on to asr because i thought it use the original hole where the oem swaybar goes to.
yes the ASR bar will bolt right up. maybe you got the EG version? because the one i got bolted right in with all teh hardware that was included.
edit: my bad i thought you wwere talkin bout the asr bar. the ST bar still bolts in tho. no need to drill anything. i'll be including pics in another post while i play with the camera
the eg asr is longer then the ek version. like said before it bolt right up, or atleast mine did. and if not take 5 mins and drill new holes in the subframe to match it up with the asr
the egg version where the lca bolt goes would be cover by the sway bar mount where the ek isn't.
****en sweet!!!!
so the ek asr brace will work with my suspension technique.
wtf so the st sway bar end links dnt go in those wholes in the lca as the stock sway bars do?
also will the sway bar rub in the lca wen sus flexes?
it does use the original holes.... you can see that in my pics. they're just spaced farther outward towards the back of the car.
edit: here's a pic of someone elses ITR sway bar.
omg installing asr was a bitch, **** took me 4hours because of the stupid LCA bolt wont go in and as for the swaybar i have to fight the damn thing.
having no lift suck *****.
hmm i wonder why your's looks smaller/shorter then mine. maybe i messed up my install. did you just buy the rear sway bar? my peice that holds the end link is longer.
yes i bought both swaybar front and rear with instruction that is made for ex and my car is a dx.
monEmakindave
16
Feb 2, 2011 11:02 AM
gambit1982
Suspension & Brakes
Oct 5, 2005 10:09 AM
S2K2S
Aug 9, 2002 09:27 AM
