Help with fitting a DA lip
Old Aug 29, 2009 | 01:38 PM
MarksCivic's Avatar
Default Help with fitting a DA lip
I've tried searching, but can't find the specific info that I need. I have a lip from a 90/91 Integra that I'm trying to put on my 90 Civic hatch. All the attaching bolts across the front and at the corners line up perfectly, but I can't figure out a good way of attaching the ends. The bracket thing that attaches the ends on the Integra doesn't work because you have to trim a couple inches off the lip. How do people attach it while still keeping the lip level and tight against the bumper? Is double-sided tape enough?
Thanks for your help!
Old Aug 29, 2009 | 01:55 PM
beansandrice's Avatar
Default Re: Help with fitting a DA lip
Double sided tape stands a snowballs chance in hell.
Mine lines up really nice. It is not a DA lip but close to it. For the ends you speak of I just drilled a hole on the inner lip lining up to the bumper.
I am pretty sure most folk do this.
Old Aug 29, 2009 | 02:06 PM
BiG ChOr!Zo's Avatar
http://www.thezcr.com/forums/showthr...&highlight=lip
Old Aug 29, 2009 | 02:56 PM
sde780's Avatar
Drill a hole, then zip tie
Old Aug 29, 2009 | 07:24 PM
garageEF's Avatar
Originally Posted by sde780
Drill a hole, then use proper hardware
Fixed.
I have actually had a lip stolen simply because it was zip-tied and easy to remove.
Old Aug 29, 2009 | 07:34 PM
sde780's Avatar
On the flip side, I'd rather crack/scrape a $2 lip than crack the bumper.
I cracked my bumper because I used bolts to hold the lip on. never again. I just have 1 bolt in the middle so it doesnt completely fall off in case i scrape it
Old Aug 29, 2009 | 11:08 PM
MarksCivic's Avatar
Thanks for all the suggestions. I ended up attaching the ends with some longer bolts going into the Integra fasteners which slot into the bumper perfectly. It's not a 100% perfect fit against the bumper, but good enough that nobody else will notice. Here's a pic!
Old Aug 30, 2009 | 06:01 AM
jhammond_82's Avatar
Reject Papi
mine was held on by drywall screws. noones down there looking how the lip is installed anyway, so who cares.
Old Aug 30, 2009 | 07:01 AM
That looks really clean
92'hatch
Jul 29, 2011 04:01 AM
JDMCIVICMAN1992
Dec 3, 2007 04:41 PM
909ej195
Apr 27, 2007 11:45 AM
FR-MOB: ThE bEe GuY
Jul 20, 2005 08:30 PM
