Tein suspension for ITR
Old Aug 26, 2002 | 04:12 PM
typerfans's Avatar
Default Tein suspension for ITR
does any one using the Tein coilover suspension on their ITRs? any comments, suggestions, reviews?
Old Aug 26, 2002 | 04:13 PM
uNF$@#!'s Avatar
Default Re: Tein suspension for ITR (typerfans)
nice suspension, watch for rust. I believe they are 14 way dampning adjustable (the HA) the HA's have a suggested maintenence schedule i didnt want to follow
the suggestion is to go with another suspension for instance zeal b6 unless its a track car. I would not suggest the tein HA's for daily drivers.
if you told us which tein you were thinking of going with that would help alot.
[Modified by Soup ****, 8:16 PM 8/26/2002]
Old Aug 26, 2002 | 04:18 PM
mafay2's Avatar
New User
Default Re: Tein suspension for ITR (Soup ****)
Get the RA or higher model, then you don't have to worry about rust!!
Old Aug 26, 2002 | 04:26 PM
uNF$@#!'s Avatar
Default Re: Tein suspension for ITR (mafay2)
the HA's is the complete coilover system which are revered much higher quality than the RA. I think the RA are cheaper with no damperning adjustability.
Old Aug 26, 2002 | 04:29 PM
typerfans's Avatar
Great ride quality and improved handling are the major concerns. I don't race nor hard driving a lot. The ITR is my daily driven car, so I don't want to feel bumpy everyday to/from work
my budget is around 1000-1400. what is the best suggestion?
[Modified by typerfans, 1:30 AM 8/27/2002]
mafay2's Avatar
New User
Check out the Tein website, RA is higher model than HA!!
Old Aug 26, 2002 | 04:42 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
You had that wrong Soup ****. RA, RE and RS are the monotube, all-aluminum, higher end models than the HA (twin tube, steel body). The next step up would be the N1.
Old Aug 26, 2002 | 04:45 PM
Looose_R's Avatar
Default Re: Tein suspension for ITR (Wai)
i got the superstreets and i love them. you can rebuild them for 75bucks a piece and you dont have to ship them out of the country liek Zeals. at well under a grnad i think they are a great street, and ocassional track coilover. if your more seriosu about racing, maybe get some stiffer ones, but the SS on level 16 is plenty stiff for me
Old Aug 26, 2002 | 04:49 PM
uNF$@#!'s Avatar
thanks for the correction. It's been a long time since i've looked at the tein lineup
Old Aug 26, 2002 | 05:30 PM
zer0zer0 TypeR's Avatar
HA's and RA's are exactly the same except like Wai said the RA's are made of lightweight aluminum and the upperpillow ball mounts are standard. HA's don't come with upperpillow ball mounts. i have the HA's and i love em.
Old Aug 26, 2002 | 06:33 PM
Wai's Avatar
Wai
Default Re: Tein suspension for ITR ('00TypeR)
Oops you had it wrong again.
Besides the material used (aluminum vs steel) and upper pillow mounts, HA and RA have totally different internal designs.
HA - 35mm diameter valve, twin-tube design (lowly pressurized, fluid and air are in direct contact)
RA/RE - 45mm diameter valve, mono-tube design (highly pressurized, fluid and air inside are separated by a movable piston)
RA and RE have identical internal design. The only difference is that the RE has 2 sets of threads on the shock body; one for spring preload, one for total shock length. So RE is a bit more expensive.
Next step up would be the RS with remote reservoir; top of the line would be the N1 with 20 levels of adjustability.
P.S. I don't work for Tein, just did some research on their model lineup when I planned my suspension upgrade.
Old Aug 26, 2002 | 06:42 PM
98itR484's Avatar
Tein HA w/ upper pillow mount =
When the setting is on 1 it is just a little bit stiffer/bumpier than stock, put them up to 16, and you'll feel every crack in the road. Tein sells special rust proof spray that basically eliminates any chance of rust, or you can use wd-40. I got my tein HA's w/ pillow mounts for about $800 brand new, never used. For that amount of money, i dont think anything else can do better
Old Aug 26, 2002 | 06:43 PM
ITRinEJ1's Avatar
Default Re: Tein suspension for ITR (98itR484)
just a FYI since ppl are still discussing about HA, its discontinued now
Old Aug 26, 2002 | 07:06 PM
Obee1.8's Avatar
If you don't race and don't drive the car hard,even if you do drive the car hard,the factory suspension is extremely well balanced and should be more than enough to satisfy your street driving.
Old Aug 26, 2002 | 07:09 PM
Smitdog's Avatar
Default Re: Tein suspension for ITR (Obee1.8)
Buddy Club Race Spec Dampeners here and loving every bit of them!!
Old Aug 26, 2002 | 07:11 PM
done's Avatar
Default Re: Tein suspension for ITR (Smitdog)
Get RAs, they are soo fun good shiet to
Old Aug 26, 2002 | 08:31 PM
98itR484's Avatar
Default Re: Tein suspension for ITR (ITRinEJ1)
yes they are...they have been replaced w/ the SS model
Old Aug 26, 2002 | 08:53 PM
GokuSSJ4's Avatar
has any one had any problems with the SS , noice wise or anything at all???
Old Sep 9, 2002 | 02:05 AM
bullz's Avatar
Default Re: Tein suspension for ITR (Spoon1)
So how about the SS for a daily driver. I want a smother ride, but a complete damper system.
Old Sep 9, 2002 | 04:51 AM
Asahi's Avatar
Didn't see this as a correction in what I read. TEIN's are all 16 way adjustable
I have had the HA's for a year and 5 months with no rust and no problems. Been on the track twice and 2 seaons of Auto-X. SS's are a great option for someon that wants a complete set at an affordable price. If you have a $1500 budget I would get Zeal Function B6's.
tvman
Sep 2, 2005 10:00 AM
hatchlessrex
Jul 11, 2004 01:22 PM
bcrl
Feb 21, 2004 02:48 PM
JungleJ
Feb 1, 2003 12:46 PM
