ls 5th on 4.7 itr tranny
Old Aug 29, 2009 | 07:47 AM
roycivic92's Avatar
Default ls 5th on 4.7 itr tranny
hey fellas just need ur advice on this decision, should i do it or not. i love the fact that i dont need to down shift but gas goes fast. will it really bog the car down and what rpm at 80 mph. need u guys help on this.
Old Aug 29, 2009 | 08:06 AM
roycivic92's Avatar
Default Re: ls 5th on 4.7 itr tranny
any advice
Old Aug 29, 2009 | 08:10 AM
Shalom's Avatar
IMO it is not needed. I love the 4.7 trans as is. I would consider it more for a 4.9 FD.
Old Aug 29, 2009 | 08:14 AM
JDM_nUt's Avatar
If you change over to 4.7 final drive you will be in VTEC @ that speed. You'll use more gas, the plus side to having the 4.7 is that you'll have quicker acceleration, but your top speed will drop to around 137mph vs. 150mhp w/the 4.4 final drive.
Old Aug 29, 2009 | 08:21 AM
roycivic92's Avatar
i have the 4.7 but i was thinking of changing the itr 5th for a ls 5th i have a gsr 5th in the garage but i hear there the same asthe itr 5th
Old Aug 29, 2009 | 08:46 AM
Shalom's Avatar
You must have a busted 4.7 and or really low vtec engagement setting. Should be able to hit at least 95 mph with 15" wheels/tires (say 205/50-15) before vtec engages in 5th gear.
Old Aug 29, 2009 | 09:50 AM
JDM_nUt's Avatar
A buddy of mine has his vtec engagement low, I belive @ 5500 rpm. I've though about getting the 4.7 final drive, @ this point I don't need it.
Old Aug 29, 2009 | 10:21 AM
1GreyTeg's Avatar
4.93 or hang it up... I DD'd it for 2 years. IMHO the taller 5th just isn't needed for any of the 3 FD's mentioned.
Old Aug 29, 2009 | 03:49 PM
roycivic92's Avatar
cool thanx for the advice the itr 5th is staying in.
Old Aug 29, 2009 | 04:30 PM
Shalom's Avatar
Good choice, not worth cracking open the transmission.
On another related point, doesnt VTEC only engage under a certain percentage of throttle? IE it doesnt open while cruising, but more towards wide open throttle.
eltiny12
Transmission & Drivetrain
12
Apr 23, 2013 06:08 AM
eltiny12
21
Mar 8, 2013 09:21 AM
roycivic92
Oct 19, 2011 12:44 AM
99lsvtecauto
18
Nov 22, 2004 08:28 AM
sicilian2k1
Sep 19, 2001 08:16 AM
