95 Civic Car cranks but won't start
ok so thread number 2 on this eg i just picked up.
here is the run down..did re wire my headlights, last night. drove the car and it ran great
woke up this morning and the car just cranks and wont' start...first off battery was dead
jumped it and just cranks over no CEL on only at start up like normal..
check spark... pull a spark plug wire one at a time and put a spark plug in it have a friend turn it over see if the spark plug sparks do it to each one of the wires..... if you have spark on each check fuel it could b a bad injector or bad fuel pump...and check ur grounds....especially the one bolted to the thermostat housing
