H22 type R euro engine to a 97 SE
I was going to spend $1k on rebuilding my F22B2 instead I'm going to try to put a H22 euro engine in instead, $1100 Better end result.
So the question is will the wiring harness for the euro match the accord? (I know you have to run a vtec wire and switch a few around)
Will my F22b2 auto be a workable mate? Shift and rpm matching The only thing I'm confused about is the Computer working with this.
Will the US H22 computer work with the Euro engine when I get a auto H22 ECU?
The H22A4 ECU & TCU will probably run the H22A7 but you will more than likely loose all of it's Euro-R gains. You would most likely end up with an over cam'd, de-tuned engine. You will also need the TCU (28100-P5M-A06) for the A/T ECU (37820-P5M-L55) that you use.
I'm looking to go with the H22A with a H22A trans. The euro block is just more work, H22 seem more effective. I heard there might be ac/steering issues with the brackets. The only thing I want to is fab. the mount and steering house.
1. Will my gas milage be around 28-32 on the highway
2. What will be my 0-60 times with the auto. I saw a 210hp manual do a 6sec on youtube. In a accord very impressed.
3. I have a SE with the remote locks that works, will this be disabled when I install the auto H22A ECU? Is this a separte computer.(I'm usually good with this but haven't had time to look at car to see or go to Alldata @ the library). I love my remote!
4. Should a auto tenisioner be fine with stock HP? I read that is if you put more power on the engine it puts load on the cams then the auto tensioner is stressed. Is that theory Right?
5. With the auto shift link fit this tranny? I know this cruse requires a bracket mod or different throttle body.
Prelude_1997
Aug 17, 2004 08:35 PM
