custom intake manifold
Old Aug 29, 2009 | 01:50 AM
efjones9's Avatar
Default custom intake manifold
I want to make a custom intake manifold. And I'm wondering wat is the best design for our hondas. I just want some ideas that u guys have. I know the less bends the better. But I want to see what everyone has in mind. Thanx
Old Aug 29, 2009 | 08:54 AM
9bells's Avatar
OG Fabricator
Default Re: custom intake manifold
I can tell you that making it a center-feed will make good gains.
Look at IPS, they have good power gains, and they have a central TB.
Use the largest "bells" inside that you can fit.(air horns?)
Don't make the plenum massive if it's n/a.
Good luck!
Old Aug 29, 2009 | 10:39 AM
efjones9's Avatar
It's for a n/a. What about the runners. Which are the best for high compression engines. I searched and got mixed answers..short runner= ?? Opposed to longer runners? Also angle of injectors?
Old Aug 29, 2009 | 12:02 PM
redboost10's Avatar
in my opinion, you cant get much better injector fire angle than oem from honda. the fuel shoots right on top of the intake valve.
Old Aug 29, 2009 | 03:18 PM
efjones9's Avatar
ok cool. i was thinking to put the injectors before the tb. i was thinking that it would make air/fuel mixture better
Old Sep 5, 2009 | 04:15 AM
DaveF's Avatar
bad idea, you will run into distribution problems with anything before the TB.
Old Sep 5, 2009 | 06:00 AM
mikesrex's Avatar
You should be able to calculate what your runner dimensions and plenum size should be for the goals you have for your specific setup. The real question in this thread should be what formulas should I use for designing an intake manifold, and where do I get them?
Old Sep 5, 2009 | 06:16 AM
downest's Avatar
How would that be a bad thing really?
Old Sep 5, 2009 | 06:55 AM
tepid1's Avatar
It's not. That is what you want....
Old Sep 5, 2009 | 08:17 AM
redboost10's Avatar
read my post, never said it was a bad thing. I said "you CANT get much better injector fire angle than oem..."
Old Sep 5, 2009 | 06:36 PM
downest's Avatar
My bad! Kind of tired lately, reading owns me
Old Sep 5, 2009 | 06:40 PM
Jenkinsal2's Avatar
Dont feel bad i just did the same thing. If you make some sketches i would be willing to try and draw it up in solidworks for you and maybe do some computer flow testing when i have some spare time.
Old Sep 5, 2009 | 07:40 PM
kommon_sense's Avatar
Take a look at some of the honda cbr's from a few years back. Their intake manifold used 8 injectors. They had the first set on the itbs firing at the back of the valve. The second set was further up the intake track and sprayed at higher rpms. Having the injectors further away allowed for better fuel atomization.
so idea of moving them further up is good (would recommend doing this with a secondary set of injectors), but might be simpler to stick with one per cylinder to avoid the distribution problems mentioned earlier.
Old Sep 5, 2009 | 10:36 PM
redboost10's Avatar
no problem, i honestly think that is why these b-series heads are so efficient. what other manufacturer sprays the injectors right on top of the valve like honda does.
HellaFab
Welding / Fabrication
11
Nov 19, 2013 11:59 PM
Hahnduh
Oct 18, 2007 10:04 PM
94Integra_Ls
Jun 20, 2006 05:32 AM
shutdown
13
Jul 23, 2005 03:19 PM
allmotorchick
39
Jan 4, 2004 05:09 PM
