NEED HELP PLZ What would cause these codes?
What would cause these codes to come on at the same time? plz help
P1298 Electrical Load Detector Circuit High Input
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0500 Vehicle Speed Sensor Malfunction
Do you know where the fuse is? Did you replace the fuse with a known good one?
All four sensors throwing those codes are protected by 7.5A fuse 15 under the dash. Check again.
ok i just looked at it and i dont know why but there was no fuse there. So im resetting the ECU and im turn on the car and see if the codes disappear
After installing a new 7.5A fuse and resetting the ECU, if the CEL turns on again and the same codes are thrown, then check whether 7.5A fuse 15 has blown. If so, take the car to a good mechanic who can repair the wire harness short described in the TSB that I posted.
Well once again i seem to have missplace a fuse and proven to myself that im not all that bright , but some how im going to learn from this. Thanks guys you've been a really big help. Its folks like you that make me come back to Honda-tech.com all day everyday
sparrow1
Oct 27, 2015 12:23 PM
delsolcrazy
May 5, 2005 03:06 PM
