Uh oh.. Broken ZC crankshaft pulley & ZC Downpipe - which pipe can I use
Old Aug 26, 2002 | 03:43 PM
BigDaddyRich's Avatar
Default Uh oh.. Broken ZC crankshaft pulley & ZC Downpipe - which pipe can I use
OK so the very outer lip of the crankshaft pulley has about a 3 inch piece broken off. IT doesnt affect the belts in any way because the broken lip is on the far outer edge of the pulley that resides around the hole to access the crankshaft bolt. (ZC guys will know what i mean) the alternator and AC portion of the pulley is fine. My question is will this broken lip cause a mis balance and vibration during engine use? Can I swap my Si Crank pulley if they have the same timing marks and circumference and all that junk?
OK I realize the ZC exhaust manifold is a 4-2-1 header whereas the Civic Si header is a 4-1 header. Seeing this dilemma. Which doner car downpipe can i use to join both? 89 Integra or somethin? Thanx for your help in advance
I will post a pic of the broken pulley to illustrate soon
Old Aug 26, 2002 | 04:16 PM
wronghand's Avatar
Default Re: Uh oh.. Broken ZC crankshaft pulley & ZC Downpipe - which pipe can I use (BigDaddyRich)
You definitely want to change the crank pulley. Either a an Si or DX should work fine. As far as the down pipe, the 92-95 Si or EX downpipe will match up with the top half of the ZC manifold. The only problem you may run into would be the downpipe matching up with the cat.
Old Aug 26, 2002 | 04:21 PM
Default Re: Uh oh.. Broken ZC crankshaft pulley & ZC Downpipe - which pipe can I use (wronghand)
Old Aug 26, 2002 | 11:52 PM
nihkon's Avatar
I had the same problem with my crank pulley when I bought it. But since we don't have power steering, and no A/C. . .I decided to leave it. My car gets pushed pretty hard, and it's ran fine for the past 2 months.
But to be on the safe side. . you'll probably wanna change it out.
Old Aug 27, 2002 | 04:06 AM
therealciviczc's Avatar
I ran this setup for quite some time. It hangs about 3/4" - 1" lower than the ZC bottom piece would. As long as your car isn't lowered beyond reason, you'll be fine. My car was lowered about 2" and it never seemed to rub.
Old Aug 27, 2002 | 05:23 AM
Default Re: Uh oh.. Broken ZC crankshaft pulley & ZC Downpipe - which pipe can I use (therealciviczc)
Thanx for the input guys.... I appreciate your comments!!
Old Aug 28, 2002 | 05:43 PM
Hey WrongHead ...... are the Crankshaft pulleys from the Si or Dx the same diameter as the ZC?
Old Aug 28, 2002 | 05:52 PM
Malgerus's Avatar
get the pulley off an 88' D16A6... it's lighter than the 89-91's.
Old Aug 28, 2002 | 05:53 PM
Ham'ed Hatch
Guest
Posts: n/a
what he said
Old Aug 28, 2002 | 08:27 PM
AbaZ's Avatar
Actually if you can get a DX pulley they are the lighest out of the stock D-series, they have 2 belt runners on the pulley..
Jeff
Old Aug 29, 2002 | 04:48 AM
keithv's Avatar
Default Re: Uh oh.. Broken ZC crankshaft pulley & ZC Downpipe - which pipe can I use (AbaZ)
i'm using an HF pulley, but i had the entire bottom end balanced along with the HF pulley (i was doing a rebuild, so i went with the lighter pulley).
d15maverick
11
Feb 13, 2005 08:00 AM
StupidSlowRSX
May 5, 2004 06:58 PM
quis23
Jul 14, 2003 10:40 AM
