HELP! ANT GET IT TO START!
Old Aug 28, 2009 | 06:46 PM
gsrkid24's Avatar
Default HELP! ANT GET IT TO START!
i just bought a gsr and i was driving down the road and it just shut clean off...no sputter or nothing? i disconnected the battery terminal to reset the computer but it didnt do anything. The engine turns over fine when you crank it, it just isnt catching at all? can u give me some tips or tests to run?
Old Aug 28, 2009 | 08:41 PM
eaglewesman's Avatar
Default Re: HELP! ANT GET IT TO START!
Most likely your main fuel relay. The part is around $60, easy fix right under the dash. I had the same problem - it would shut off and wouldn't start for another 15 minutes (it would crank, but no start). Replaced the relay and no problems now.
Old Aug 29, 2009 | 08:40 AM
worx's Avatar
check if your getting fuel, spark, first
Old Aug 30, 2009 | 01:09 PM
Integ808's Avatar
same problem as me...
i hope u find the problem.
Old Sep 30, 2009 | 11:25 AM
gsrkid24's Avatar
ok so the main fuel relay is under the dash? where exactly? and how can you check it?
Old Sep 30, 2009 | 11:26 AM
gsrkid24's Avatar
ok so where exactly is the main fuel relay? and how can i check it?
89pre2.0si
Jun 7, 2008 11:36 AM
blackep925
Apr 12, 2008 04:59 PM
D50boy
Acura TL, RL & ZDX
14
Aug 16, 2007 04:35 AM
ducky21
Jul 28, 2006 03:10 PM
chickenandpickles
Jul 18, 2005 11:11 AM
