DEPO fog lights killed my car!!
Well sorta. I cant start my car now, it doesnt even click over, the electrical stuff still works like the headlights, radio, air etc. But the engine WILL NOT start. I had to push start the car and it fired up just fine to get it home, so it's not the engine. The only thing I have done was last night I installed some depo fog lights. I was unclear on the instructions online and I hooked it up the way it seemed it needed to be, what did I do wrong? And what can be the problem, why wont the car start? I have tried jump starting it but nothing, so the battery is good.
I just put brand new OEM spark plugs and spark plug cables on about two weeks ago, I dont think that has anything to do with it though, just thought id mention it.
on the fuse panel. I see you used open spots one and two. I believe #1 is constant 12v and #2 is switched. So just make sure your not draining the battery because your lights will work even if the battery doesnt have enough juice to turn over the starter. My battery went dead(almost) it had 7v left and all my dash light would work and headlight but just a click when trying to start. It sounds like something may be draining the battery
farkiller, it doesnt make sense if you install your own fog light kit but you dont know how to determine a blown fuse
it may be goodto learn some basic things before or WHILE your tinkering around your car
http://www.hondacivicforum.com/forum...ad.php?t=61880
ok, understood. have you checked that starter for loose wire, corroded wires. My little 1/4 spade plug that goes to the starter for the signal also comes loose when I dont want it to. And sometime it just gets a little corroded/rusty from the salt in the air and gives me problems. Have you checked the main relay?
Could it have anything to do with my alarm? The guy I bought the car from installed it, and if I open the door with the key and not the remote the alarm will go off and make the car not start unless I put the key in the ignition and press this button 5 times. Also there is a fuel cut off switch, but it''s not on, and there is a little chip under the steering wheel area that if taken out makes the car not start, but the chip is in.
I am not trying to rub you the wrong way but at what point did you think you were capable of wiring the fog lights when you can't even check if a fuse is bad. However the fact that you are typing on this computer means you can handle the simple problem solving involved in diagnosing the problem. Just think about it like anything else... in a systematic fashion. Here are some pics you should be able to tell good from bad if there is a break it is bad...When you turn the key do you hear a click?
OK guys I got it working. I pulled a few blue fuses out and looked at them and put them back. Also on that little chip that when taken out makes the car not start it has a little button on it, so while the chip was inserted I pressed the button then it fired up.
NOW.
Can someone PLEASE tell me exactly how to hook up these god awful depo fog lights properly? I do not want to blow a fuse or something in the future.
NOW.
Just read this. On a forum.
"i have an ebay kit and the genuine honda kit..
i never installed the ebay one but i had a look at it today... a started tracing the wires and within a few minutes, it started making perfect sense...LOL...the confusing parts were two unused connectors on the sub-harness(mine was a 3 harness kit). turned out that the two connectors were both electrically connected together and aren't even used for anything.
if i have time, i'll wire it up on a workbench showing how to connect up the harness..."
So all I connect is the one one pin connector and leave the other two two pin ones that I had to the fus box not connected?
he's saying to mock you because you didn't know how to tell if a fuse is bad, seriously though bro you could have just googled "blown fuse". I really don't know where to start with the fog light that might be too big a task
Dang im sure someone on here has installed depo fog lights before.
