max hp attainable on a 2.5 inch dp and exhaust? looking for info
Old Aug 28, 2009 | 04:29 PM
4drhoar's Avatar
Default max hp attainable on a 2.5 inch dp and exhaust? looking for info
like the title says. im shooting for 400whp on pump gas with a piston and rod ls/vtec a/c p/s compatible setup.
car has a real nice stainless 2.5 inch exhaust and was wondering how bad id suffer with the full 2.5 inch compared to a full 3 inch? can 400whp be made on a full 2.5 inc dp and exhaust?
Old Aug 28, 2009 | 05:43 PM
littleblue's Avatar
From: On a island w/ only a bridge to leave it, U.S.A
Default Re: max hp attainable on a 2.5 inch dp and exhaust? looking for info
I'm at 392 with 93 oct b18a1. 2.5inch dp cp piston/eagle rod.
Old Aug 28, 2009 | 05:53 PM
4drhoar's Avatar
whatr u running for a turbo and boost level?
Old Aug 28, 2009 | 05:58 PM
abnaasefmb's Avatar
I’ve seen 380ish through a 1.5”, it happened when a guys flex bellow malfunctioned and expanded on the inside. I think the car ended up making 600 after that was fixed. Can you do it yes, would you otherwise have a bit more power and earlier spool, probably. In the end it’s your call, so try what you like. You can always give it a go, and upgrade later if you want.
Old Aug 28, 2009 | 06:00 PM
littleblue's Avatar
A/R 60 392 whp @ 15psi.
Old Aug 29, 2009 | 06:34 AM
DaveF's Avatar
i had a b series pumpgas car doing 450hp/315tq, through 3inch DP/ 2.5inch exhuast.
hialeahzbg
Mar 2, 2010 11:22 AM
AzntaggeR
Mar 12, 2005 09:49 AM
n0pinitr0us
Dec 23, 2004 09:43 AM
gsr sol
Feb 9, 2003 06:19 PM
b18cTurbo
Feb 26, 2002 06:41 PM
