horrible gas mileage with my d15b1
Man, I have horrible gas mileage. It's a d15b1 dpfi it use to get like 40mpg street. Like 45 highway when I first got it. Now I'm gettin 27highway and 20 around town. Anyone have any suggestions. Only mods is a not so cold air intake. Just replaced the plugs and wires with ngk.
Just look on the ECU and see if there are any flashes when you turn the key onto accessory.
When you turn your key on does your CEL come on and then go off with the fuel pump priming? Just making sure the bulb isn't burnt out thats all.
When was the last time the PCV valve was replaced?
See other tips specific to c. 1990 Civics at http://honda.lioness.googlepages.com/gasmileagetips
Here is a test you can do of the PCV valve: http://media.honda.co.uk/car/owner/m...k301/6-173.pdf
However, I do not think this test is conclusive. If the valve is non-OEM or more than five years old, replace it. Should run you $20 or so or less.
When I changed my headgasket I did a compression test.the head was worked on did a valve job and I just checked valve lash. It wasn't completely cold but it was still within spec. Cap was recently replaced and the rotor had some kind of dust on it. So I cleaned that too. Just finished my tank off and it's gettin 25.4 mpg? Wtf and I have no turbo. Lol I'm goin to get a o2 today
injectors
Changed the o2 sensor and gapped the sparkplugs. Still getting bad mileage. It went up from 25mpg-30mpg. Could anything else cause it to run rich? It's still runnin rich but not as much as before
You could try and borrow a different DPFI ECU to make sure that's not the culprit. Since you have changed everything out that really deals with fuel.
