Wheel Hop?
Old Aug 26, 2002 | 02:46 PM
HarryB's Avatar
From: Where All Funky Things Come From...., Stankonia, USA
Default Wheel Hop?
Could a bad clutch cause wheel hop when trying to burn out with Nitto DRs? I took my car out to the track this weekend (First Time) and I was getting lot of wheel hop when doing my burn out. I was told to rev up to 6k and drop the clutch to get the tires spinning and get a good burn out. I also have a bad throw out bearing that is getting fixed.
Old Aug 26, 2002 | 03:09 PM
Incognito's Avatar
Default Re: Wheel Hop? (civic@uofw)
Clutch could be it, but chances are it's your alignment, too much air in the tires, or your car is too low. Could also be bad motor mounts.
Old Aug 26, 2002 | 04:02 PM
DLB1994's Avatar
Default Re: Wheel Hop? (Incognito)
motor mounts and to much air in the tires
Old Aug 26, 2002 | 07:23 PM
EVOCELICA's Avatar
New User
Default Re: Wheel Hop? (DLB1994)
motor mounts to much air pressure and soft suspension
Old Aug 26, 2002 | 08:08 PM
97hb's Avatar
Most likely too much air pressure.
Old Aug 26, 2002 | 08:25 PM
AllMotorITR's Avatar
New User
Default Re: Wheel Hop? (97hb)
What motor mounts would help this?
Old Aug 26, 2002 | 09:58 PM
EVOCELICA's Avatar
New User
Default Re: Wheel Hop? (Boostin ITR)
energy suspension makes inserts
Old Aug 27, 2002 | 12:42 PM
HarryB's Avatar
Default Re: Wheel Hop? (EVOCELICA)
thanks y'all.
Old Aug 27, 2002 | 12:58 PM
SoCal ITR's Avatar
RSX_S
10
Jun 2, 2008 11:09 AM
inkong
12
Jan 15, 2007 12:05 AM
teddy_dc2
May 2, 2006 10:32 PM
allmotor99lude
Nov 23, 2005 09:27 PM
zexifiedlude
Apr 4, 2005 05:22 PM
