car starts then dies randomly
Old Aug 28, 2009 | 04:17 AM
hondamatic88's Avatar
Icon6 car starts then dies randomly
ok, i did search for a while but im still not sure what is going on.
i drive a 93 ex with 50,000 on a rebuilt motor.
heres whats going on: in the morning i start my car and it starts great, i head to I-5 and after about 5-10 mins my CEL comes on and i have NO POWER, even when i downshift i cannot accelerate. my car continues to slow down until i pull over and then it dies. i cannot restart the car unless i turn the key all the way back to off and then try to start it again. when i do this it starts right up and i have NO CEL and the car drives normal. this is a random problem that i cant seem to figure out. any help would be great.
Old Aug 28, 2009 | 04:22 AM
crxboy909's Avatar
Default Re: car starts then dies randomly
you might have a fuel problem.... find out what your CEL is.....
Old Aug 28, 2009 | 04:24 AM
when i restart the car i dont have a CEL i only have it for the 10 secs before the car dies..
Old Aug 28, 2009 | 04:32 AM
crxboy909's Avatar
next time ur car dies dont turn ur ignition all the way off check for ur code first....
Old Aug 28, 2009 | 04:33 AM
crxboy909's Avatar
here's how to check for the codes...
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Aug 28, 2009 | 10:30 AM
ok i took the car out for a drive and waited for it to die. i checked the CEL like u suggested and the code was: 15 Ignition output signal
i went to autozone and bought a new distributor and that solved the problem. turns out my ignition switch thingy in the distributor was bad, but the cost difference was so small that i just bought a brand new distributor. thank you very much for you help! it is much appreciated!
thunderfck
Mar 4, 2013 04:19 PM
illios
12
Sep 26, 2012 07:09 PM
teknikEG6
Apr 15, 2006 03:04 PM
Project_SOHC_EX
Aug 25, 2004 12:09 PM
