ls with test pipe in civic do i need a custom catback
alright the motor is a 96 ls in a 96 civic coupe dx has 4-1 headers leading to a "high flow cat" its a cheap ebay one but it replace the tackweld that was there when i got it my question is do i need a custom catback for this setup or will a cat back from a civic bolt right up
I think you might have to because the Integra test pipe will make your mid pipe not fit right. What length is the test pipe? I am running a GSR 4-1 header to a 2.5 Integra test pipe and I needed a Integra mid pipe. It was a tight squeeze though.
get a catback thats supposed to fit the car. only thing you will probably have to modify is the length of the cat or testpipe. which is cheaper then getting a full exhaust custom.
