Welding Table Top
Hey guys,
I'm building a new welding table for myself, and I am going to use a 1/4" sheet for the top. I don't want to go any thicker for a few reason. I know it's on the thin side, but I think the table is braced enough to a point whre the top shouldn't sag or bend. I've attached a few pictures and some explanation of the construction of the table. Do you think I need any additional bracing for the top? The material used is 2x2x0.25" tubing.
I wanted the table to have adjustable legs (to level it), so I bought some 3/4" bolts and turned the heads flat it in the lathe.
Then I turned down about 80% of some nuts to a 1" diameter on the lathe, leaving a little flange on.
I made some 2x2" plates with a 1" hole in the center of them.
I pressed in the machined nuts in the holes and welded them on the back side.
I TIG welded the plates to 6 2x2 pieces of tubing that I had cut, which made up the legs.
I MIG welded the top. The top of the table is constructed out of 2x2x0.25" steel.
Welded the legs on.
I used some 1.5x1.5x1/8" tubing to "tie in" all the legs together.
So, do you think additional bracing is needed for a 1/4" table top?
Thanks for looking!
Welded the legs on.
Thanks for looking!
for the front of the table I wouldn't have run the braces along the bottom because to get to a tig pedal if you tig you have to step over the brace, or in gerneral its kinda a pain to sit
i like the adjusters though
I always sit a few inches away from the table with the pedal on the side. It's kind of weird, but that's what I'm used to. I'm not really worries about the braces getting in the way of the pedal.
I need to make a table so bad... My main issue is not having a MIG welder. All my friends with MIG welders are flakes and never wanna help me. I NEED A TABLE SO F-ing bad.. I would even buy one if I could find a decent one local..
Thanks! It's not "my" shop. I only have an office, and own half of the tools.
Haha, my boss lets me keep my tools there and work on my own stuff after work. I love the 15,000 sq. ft. shop, but the lack of air conditioning in the 110 ºF AZ heat sucks! I'm looking forward to the winter.
The HTP, yes! It's a beast. I absolutely love it!
Why don't you stick weld it? You do have a TIG machine, right?
Haha, my boss lets me keep my tools there and work on my own stuff after work. I love the 15,000 sq. ft. shop, but the lack of air conditioning in the 110 ºF AZ heat sucks! I'm looking forward to the winter.The HTP, yes! It's a beast. I absolutely love it!
I have a 1/8" top with 2x2 1/8" wall legs. i made a vary simple 4'x8' rectangle then welded the legs. and i had the sheet bent on a brake 90 up in the back 90 down in the front.
it's plenty strong.
it's plenty strong.
I tig welded mine with no problems although it is much easier with the mig.
That's cool! Why did you do the bends? Is the table against a wall?
Yeah my table is against a wall so it keeps things from falling off the backside. Also it increased the rigidity of the sheet, Not allowing it to flex as much.
IDK about 1/4....sucks if it warps...all the $$ wasted on the sheet. I used 3/4"...its thick as hell, but i can drill holes in it and bolt the manifold flanges down to it and the table absorbs all the heat when welding...
If you never really put much heat into anything it will be fine. It just sucks when your work is clamped down the the "flat" table and then it warps and moves everything on you. I don't think I would bother with anything less than 1/2". Closer to an inch with a surfaced top is the way to go for real flatness and stability.
I know I should seriously just weld the table myself. I just wasn't sure if it was a bad idea or not. I know its gonna take longer TIG welding it.
.RTErnie
Welding / Fabrication
17
Apr 14, 2007 09:47 AM
Smashback
Feb 16, 2003 11:49 AM
