Confused on wat clutch to run!
Old Aug 27, 2009 | 11:19 AM
skunk2allmotor's Avatar
Default Confused on wat clutch to run!
i have a stroker b series set up 2.1L itr 92mm crank
250w/170t.
i have a toda flywheel and competition 4 puck disk wit dual diaphram pressure plate.
i was told by a tuner to run a twin disk.
1. is the twin disk too much?
2. is competition twin disk too much for my set up?
3. What is the best one to go with. USED FOR DRAG!
Old Aug 27, 2009 | 11:24 AM
omniman's Avatar
Default Re: Confused on wat clutch to run!
something with a lot less pressure plate thats for sure.
Old Aug 27, 2009 | 11:46 AM
i have a twin disk competition layin around dunno if i should use it my current single plate set up is reall hard to push
Old Aug 27, 2009 | 12:32 PM
b19coupe's Avatar
If you are only revving to 8,500, a stock ITR clutch will be fine. 8,500+, you will need a disc and pressure plate that can withstand the RPM. Clutch masters,ACT, etc.-"Stage 2".
Old Oct 7, 2009 | 05:32 PM
anyone using the exedy hyper single clutch or twin disc style clutch that uses single disc
Old Oct 7, 2009 | 10:42 PM
bump come on no one uses these ? i kno the k guys def run these
Old Oct 8, 2009 | 05:31 AM
redboost10's Avatar
on our all motor car we are running a custom 6.25" twin disc with only three release levers on the pressure plate...which are adjustable. not sure if you plan to clutch the car or not. the only time we use the clutch on a run is when launching. like mentioned above, you want the least pressure possible but enough pressure to not slip the clutch. we are using a gforce tranny as well. we datalog engine rpm vs driveline rpm and use this data to adjust the pressure plate.
Old Oct 8, 2009 | 05:33 AM
BeniRacing's Avatar
I roll with a ACT standard PP and an ACT sprung 6 puck. I had a competition 6 point at one point and it wouldn't like to shift above 8000+ rpm.
Old Oct 8, 2009 | 05:34 AM
timlangston's Avatar
stage 2
Old Oct 8, 2009 | 08:03 AM
PyroProblem's Avatar
Ive stayed with an ACT "extreme" pressure plate with the full face "street" disc and never had a problem. I will be using the same clutch setup on my stroker build too when its finished.Mines a daily driver so I didnt want anything too aggressive. I like the engagement feel and it grabs quite nice at ~150 ft/lbs. Id expect it to be similar at ~170ft/lbs...
Old Oct 10, 2009 | 03:37 AM
i was told to run a hyper stage 3 from exedy. im wondering if its worth it.. i had a comp twin disk but i sold it. i have a competition clutch right now and it is way to hard to push down its a dual diaphram with a 4 puck sprung disc matched with toda flywheel. i would like to run a clutch set up that i can simply put in and launch the car on slicks all day. my tuner and other builders all reccomend a twin disc.
Old Oct 10, 2009 | 05:52 AM
BeniRacing's Avatar
Well if not going to take our advice.....then why did you ask in the first place??? I would say get something/this....but you just want someone in here to recommend a twin-disc to back up your belief.
All im saying is that you dont need a $1000+ twin disk setup for an all motor build.
Old Oct 10, 2009 | 12:51 PM
no i jus want to kno if anyone using em. on a b series. i jus kno its popular wit the K's and i was askin mostly about the hyper stage3 from exedy. i asked for input on it. i have taken ur advice on the act clutch into consideration i would like to save some money of course. but the car is not a daily driven so i would like to use the best possible option with out goin over board.
Clerique
Aug 12, 2009 05:52 AM
crowder13
Jan 14, 2008 01:56 PM
whiskaz
Dec 16, 2006 01:55 PM
kaptr1d
45
Jan 3, 2005 09:49 AM
