What's the next best lube to ARP's fastener lube
Old Aug 27, 2009 | 10:08 AM
Mikey3000's Avatar
Default What's the next best lube to ARP's fastener lube
ARP's stuff is on backorder till Sep. 14th. Is moly lube the next best? This is for torquing head studs and girdle bolts.
Old Aug 27, 2009 | 10:14 AM
Ls_dx's Avatar
Default Re: What's the next best lube to ARP's fastener lube
30 wt oil. there is a different torque spec for 30 wt tho.
Old Aug 27, 2009 | 11:09 AM
SlowReaction's Avatar
Torco assembly lube.
Old Aug 27, 2009 | 11:15 AM
Ls_dx's Avatar
All of ARP's torque specs mention ARP lube or 30wt.
Old Aug 27, 2009 | 11:32 AM
locash's Avatar
KY! Oh wait, bolt lube.. Torco makes some good stuff too..
Old Aug 27, 2009 | 12:08 PM
tepid1's Avatar
ARP lube is moly based, so I personally would stick with that. It provides much more accurace vs. 30wt, but ARP provides specs for 30wt as well, so why not use that?
Old Aug 27, 2009 | 12:50 PM
1992Si's Avatar
I would think that any moly lube you buy at the auto parts store is basically the same as the moly ARP sends you.
How different can it really be ?
We use a moly lube at work for nut's we torque to 600ftlbs.
FWIW; Here's a link to it;
http://www.dowcorning.com/applicatio...9877&type=PROD
Old Aug 27, 2009 | 12:56 PM
MazworxRacing's Avatar
Pm us we got some
Old Aug 27, 2009 | 01:55 PM
lou-tdi's Avatar
KY lol
Old Aug 27, 2009 | 06:19 PM
sgnlab's Avatar
Originally Posted by lou-tdi
KY lol
Ionly came on this thred to write what you just wrote hahahaha
Old Aug 27, 2009 | 06:22 PM
rota92
Guest
Posts: n/a
I only came in this thread because I wanted to see how many people already posted that lol
Old Aug 28, 2009 | 05:12 AM
Turbo-charged's Avatar
i know its a little bit of a drive, but i have a ton of that crap if your in a bind.
Old Aug 28, 2009 | 10:12 AM
Mikey3000's Avatar
you wanna throw some in the mail to me? i'll give you some paypal.
Old Aug 28, 2009 | 05:28 PM
DaveF's Avatar
fastener lube like they send with head studs?
i use anti sieze. ..
Old Aug 29, 2009 | 03:53 AM
Mikey3000's Avatar
yeah. and what torque value do you use?
Old Aug 29, 2009 | 05:55 AM
DaveF's Avatar
arp torque spec (same number as if i were using their rebadged ****)
Old Aug 29, 2009 | 09:12 AM
Mikey3000's Avatar
lol i guess i'll just do that.
Old Aug 29, 2009 | 09:20 AM
DaveF's Avatar
ive been doing it for probably 8 years now and never had bad results from it.
Old Aug 29, 2009 | 09:57 AM
HR-1320's Avatar
After all these ? about lube , I hope you have a torque wrench capable of getting the job done right. Cuase none of this matters when your using junk tools. You could over or under torque by 20lbs with a junk craftsman manuel wrench.
Old Aug 29, 2009 | 06:14 PM
DaveF's Avatar
dont **** with my craftsmen,, sally !!
Old Aug 29, 2009 | 07:12 PM
patriot's Avatar
****, I bet your strap-on or matcos arent within 10 if you havent had it calibrated recently.
Old Aug 30, 2009 | 12:57 PM
Johnny O A20 KIller's Avatar
Pep boys sells a moly lube, you can use.
Old Aug 31, 2009 | 05:40 AM
Mikey3000's Avatar
sorry bout ya luck playboys, i'm using a less than 1 year old snap-on
slo_b18
Jan 30, 2008 08:47 AM
dohcgarage@714
Sep 17, 2006 02:24 PM
djtony5
Nov 17, 2005 02:48 PM
soLSvtec12kcraze
10
Mar 18, 2005 08:11 PM
Used2beAb16
Mar 17, 2004 02:46 AM
