"help" egine knock,code p1259(vtech malfunction)
Old Aug 27, 2009 | 04:46 AM
n/ahonda97's Avatar
Icon2 "help" egine knock,code p1259(vtech malfunction)
what up h-t, i was a idiot a few days ago forgot to add oil in my d16y8,it went low. anyway i was passing someone the other day and it kicked out of vtech and started knocking,i put 3 qts back in it but damage was already done,the code was p1259(vtech malfunction). my ? is why the knock if the vetech is malfunctioning,i was thinking rod bearing slip if so can i fix it with out taking the motoer out. i need to drive the car till i have all the parts for my kswap/ thanks for any help guys
Old Aug 27, 2009 | 07:45 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: "help" egine knock,code p1259(vtech malfunction)
you can get new bearings in with the motor in. but thats like patching a hole in a tire. from bearings spinning causes damage. VTEC works off of oil pressure. if you dont have oil pressure it will not work or slide back out of vtec. dont put a k20 in if you dont use oil in your engines
Old Aug 27, 2009 | 08:26 PM
n/ahonda97's Avatar
this was the first time in 10 yrs that i have been driving,that ive done something this stupid. i have been gathering parts when ever i can for the kswap,i cant aford to buy everything at once.so thats why i would be basically patching it for the time being. thanks for the response though.
skoodles2k6
Dec 20, 2007 03:13 PM
96-EJ6 B18C
11
Mar 2, 2005 12:46 PM
Rod.
Feb 8, 2005 03:26 PM
toooslow
Oct 15, 2003 10:47 AM
whitney
Dec 20, 2001 02:43 AM
