Would this cause low oil pressure?? pic inside
Old 02-08-2005, 07:04 AM
Rod.'s Avatar
Default Would this cause low oil pressure?? pic inside
Just out of the blue I had a problem of my oil light coming on. Only time it would come on is after I get on it hard then it would go away. I did a oil change a couple days ago I saw a little of that junk in my oil pan, in the oil filter and now in my vtec solenoid. On cold starts my oil pressure is 75-80, warm up is 30psi but few mins after that it will sit at 10psi. Could it be my bearings? Please help and no smart remarks
Old 02-08-2005, 07:12 AM
NJIN BUILDR's Avatar
Default Re: Would this cause low oil pressure?? pic inside (redturbocivic)
Sorry,looks like bearing material to me.
Glenn
Old 02-08-2005, 07:13 AM
m R g S r's Avatar
Mine sits at around 10 psi at idle, which is about 400rpm's
Old 02-08-2005, 07:27 AM
tgreaves's Avatar
That does look like bearings to me.. I would check the bearing in the bottom end to see if any of them are spun, hopefully you caught it in time before anything got messed up..
Old 02-08-2005, 08:05 AM
servion's Avatar
My buddy had this exact same thing happen to his d-series setup. All 5 mains and all 4 rod-bearings spun shortly after.
STOP driving it and check out yout bottom-end.... better safe than sorry
Old 02-08-2005, 08:10 AM
sleeprhatch's Avatar
Default Re: (servion)
yes that would cause low oil pressure, good luck
Old 02-08-2005, 12:58 PM
Kwuaymaikrup's Avatar
If it is in fact bearing material then that will explain your low oil pressure. As the bearings get eaten away the clearances enlarge therfore dropping the oil pressure. Tear it down and take a look. You still might be able to save the crank and rods.
Old 02-08-2005, 12:59 PM
servion's Avatar
Note that also, a drop in oil pressure could cause this problem. Something to keep in mind...
Old 02-08-2005, 01:13 PM
Rod.'s Avatar
Could my oil pump be getting chewed up? From what Earl told me, oil pumps go out they dont work on and off
Old 02-08-2005, 02:02 PM
servion's Avatar
My bet is that you need to tear into it and rebuilt it. Definitely replace the oil pump, because its not worth reusing... especially with this situation.
Old 02-08-2005, 02:51 PM
JSpin's Avatar
dang man.........i really hope your bottom is okay, you cant have more than a few thousand miles on it.
good luck rod!!
Old 02-08-2005, 03:26 PM
Rod.'s Avatar
Default Re: (JSpin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpin &raquo;</TD></TR><TR><TD CLASS="quote">dang man.........i really hope your bottom is okay, you cant have more than a few thousand miles on it.
good luck rod!!</TD></TR></TABLE>
i hope so too, probably only have about 2000 miles on there
wezzel19
10-09-2006 09:05 AM
non-Vtechatch18
11
05-28-2006 01:45 PM
AccordDX89
08-01-2004 05:55 PM
Tchleung
04-14-2004 10:30 AM
3.8turbo
03-06-2004 10:43 AM
Quick Reply: Would this cause low oil pressure?? pic inside
