any one making over 300whp with a fmu
Old Aug 26, 2002 | 01:13 PM
DLB1994's Avatar
Default any one making over 300whp with a fmu
if so whats your fuel setup and how much boost
Old Aug 26, 2002 | 01:16 PM
CovertFI's Avatar
Default Re: any one making over 300whp with a fmu (DLB1994)
i would like to see that. dont think it is possible thought.
Old Aug 26, 2002 | 01:20 PM
DLB1994's Avatar
Default Re: any one making over 300whp with a fmu (CovertFI)
i know its possible a guy on here with a type r made 434whp with a fmu and jinxproof99 made around 350whp with a fmu and i know its more then just them
Old Aug 26, 2002 | 01:39 PM
MaxBoost's Avatar
New User
The cybernation integra down here in Miami made 500whp on FMU's. And I think the car ran 10's.. They're switched over to stand-alone now I believe though.
EDIT: I was off only 499.2hp to the wheels.
http://www.cybernationmotorsports.com/projects.htm
[Modified by MaxBoost, 10:44 PM 8/26/2002]
Old Aug 26, 2002 | 01:56 PM
jinxproof99's Avatar
New User
361 hsp w/ 12:1 fmu. on cam2(116 octane)
i think stan made close to 380. there have been at least 15 cars to have made 350+ hsp with a fmu at inline alone.
[Modified by jinxproof99, 5:57 PM 8/26/2002]
Old Aug 26, 2002 | 02:36 PM
Mr. Softee's Avatar
Default Re: any one making over 300whp with a fmu (jinxproof99)
what size injectors jinx?
Old Aug 26, 2002 | 02:43 PM
DLB1994's Avatar
Default Re: any one making over 300whp with a fmu (94goldjungsr)
440cc
Old Aug 26, 2002 | 04:12 PM
ion_four's Avatar
440cc
Heh, I bet that idled real nice with the fmu
Old Aug 26, 2002 | 04:35 PM
Mr. Softee's Avatar
Default Re: any one making over 300whp with a fmu (ion_four)
holy ****. what psi were you at jinx? that is some crazy fuel...
Old Aug 26, 2002 | 05:02 PM
turbocoupe's Avatar
Got a friend here in town that made 345 with an FMU.
Old Aug 26, 2002 | 06:01 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: any one making over 300whp with a fmu (turbocoupe)
my previous set-up made 434whp with 440cc injectors and a 12:1 fmu.air fuel was very conservative as well.
Old Aug 26, 2002 | 07:33 PM
DIRep972's Avatar
Smarter than you
an old member from last year made 350whp on FMU and 370's w/ AFC. ran low 12's on FMU at just over 300whp too.
Old Aug 26, 2002 | 09:18 PM
New User
440cc
idled fine, moron. people have been running this set up comfortably for years.
Old Aug 26, 2002 | 09:25 PM
accordfreak's Avatar
so if i get 440cc injectors with ONLY an inline pump and 12:1 FMU, will i be ok or will i be running wayyyyyyyyy to rich?
[Modified by accordfreak, 6:25 AM 8/27/2002]
New User
Default Re: any one making over 300whp with a fmu (accordfreak)
so if i get 440cc injectors with ONLY an inline pump and 12:1 FMU, will i be ok?
add a s-afc.
Old Aug 26, 2002 | 09:36 PM
this one?? http://cgi.ebay.com/ebaymotors/ws/eB...tem=1853423237
or is the digital better?
Old Aug 26, 2002 | 09:54 PM
New User
get the digital one.
Old Aug 26, 2002 | 11:49 PM
DLB1994's Avatar
Default Re: any one making over 300whp with a fmu (turbotypeR)
what was your fuel pump and did u have stock fuel lines
Old Aug 27, 2002 | 03:58 AM
25 Year Member
stock fuel lines with a venom 100gph inline pump.you can use a in-tank pump.before this i had a walbro gss317 and made 380whp.
Old Aug 27, 2002 | 10:34 AM
BoostedSi's Avatar
How much boost were u at turbotyper and jinx? Wouldnt fuel pressure be really high at the rail?
I want to make around 350whp with an fmu. So far i have 440s, vafc, 255lph hp intankpump, btm, and 4:1 fmu. at 13psi on the dyno, i ran in the 9s and 10s in the air/fuel... so i didnt know what to do, when i took the fmu off it was leaning out bad.
Old Aug 27, 2002 | 07:00 PM
New User
Default Re: any one making over 300whp with a fmu (BoostedSi)
a t4 can make over 350 @ 14 lbs of boost where as on the same set up, a t3/4 might need 18 lbs to make that. depends on turbo size, compression, timing, dissplacement...............
Old Aug 28, 2002 | 09:54 AM
Elite Hatch's Avatar
It is easy to make over 300hp++ with just 440cc injectors, fuel pump, FMU and SAFC to control your fuel. It seems like the Northern VA area just makes fast cars and knows that you dont need a stand alone to make HP.
Old Aug 28, 2002 | 10:14 AM
X2BOARD's Avatar
Default Re: any one making over 300whp with a fmu (Elite Hatch)
Uhhh... everyone knows that... it's just that a standalone is more reliable.
<---- Less than 7 psi... FMU go "BOOM!" Fuel everywhere... that wasn't fun... at least I wasn't running hard.
X2
Old Aug 28, 2002 | 02:36 PM
Default Re: any one making over 300whp with a fmu (X2BOARD)
"any one making over 300whp with a fmu
if so whats your fuel setup and how much boost"
WAS THE ORIGINAL POST THAT I WAS TALKING TO. SO OBVIOUSLY NOT EVERYONE KNOWS THAT
Old Aug 28, 2002 | 02:47 PM
X2BOARD's Avatar
*Clap! *Clap!* *Clap!*
Congrats... now YOU know... nice 'CAPS LOCK' post... did that come stock ?
