HELP! installing my DEPO fog lights
Old Aug 26, 2009 | 06:54 PM
DOMAN!EJ8's Avatar
Default HELP! installing my DEPO fog lights
bought a set of 99-00 civic depo fog lights, just cant figure out how to install or plug it up. My car is 97 civic. not sure if the harness is different?
First picture shows
2 of the white Male plugs, plugs right into the fog lights.
Blue is most likely the ground, and the Yellow with brown plug is a FEMALE
2nd Picture Shows
Green Plug connects to the Fog Light Switch
MALE Brown plug with red wire has a Fuse Box
Blue wire with Brown plug is a FEMALE
MALE brown plug with black wire
Red wire with ARM
Relay
FUSE BOX PANEL HAS 4 OPTIONAL PLUGS
5 2 3 SPACE 1
Is this the right way of installing it?
female brown plug with yellow wire, connects to the male brown plug with black wire?
red male plug with fuse box connects to WHICH? number of the "optional plugs"? 5? 2? 3? or 1?
and the brown female plug with blue wire connects "TO THE FACTORY FOG LIGHT MALE PLUG BEHIND THE FUSE BOX? is this right?
and the blue wire and red with arms connects to grounds
just wondering if anyone can help me wire this up. thanks!
Old Aug 26, 2009 | 07:54 PM
thecruzs2007@yahoo.com's Avatar
Default Re: HELP! installing my DEPO fog lights
99-00 fogs don't fit a 97..they have different front bumpers
Old Aug 26, 2009 | 07:55 PM
DOMAN!EJ8's Avatar
i know, i just wondering about the harness.
Old Aug 26, 2009 | 08:17 PM
I_R_Baboon's Avatar
Here is the link from H and A accessories on how to install oem 99-00 fog lights. Hope that this helps.
http://www.handa-accessories.com/civ...cfoglights.pdf
Old Aug 30, 2009 | 03:40 PM
DOMAN!EJ8's Avatar
can someone post a picture of where the factory oem fog light harness under the dash? i cant seem to find it, the car is 96-98, not sure if that harness is in the same location as 99-00
Old Sep 1, 2009 | 12:26 AM
DOMAN!EJ8's Avatar
HELP!
Old Sep 1, 2009 | 05:20 PM
crx_si-r's Avatar
looks like your missing the wire that connects the under dash harness to the harness sub harness attatched to your fog lights
Old Sep 1, 2009 | 05:30 PM
nels00n's Avatar
farkiller!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 1, 2009 | 07:06 PM
TheJGB3's Avatar
Here are links for the 96-98 OEM fogs installation instructions hope this helps
1996 2/3/4 door
http://www.hondaautomotiveparts.com/.../17350_01.html
1997 2/3/4 door
http://www.hondaautomotiveparts.com/.../17977_01.html
1998 2/3/4 door
http://www.hondaautomotiveparts.com/.../18767_01.html
Old Sep 1, 2009 | 07:30 PM
DOMAN!EJ8's Avatar
are you talking about the plug that connects to the factory harness on the car? i think thats the blue wire with the brown plug
Old Sep 1, 2009 | 08:12 PM
nels00n's Avatar
i know its you..
Old Sep 2, 2009 | 09:15 PM
crx_si-r's Avatar
it should be 1 long power wire that goes from the switch to the single plug on the fog light harness
Old Sep 2, 2009 | 10:04 PM
EvilPhu's Avatar
here you go, there's a couple of picture in there
http://www.hondacivicforum.com/forum...ad.php?t=61880
98civdx's Avatar
Master Detailer
correct, blue wire brown plug..
its a sneaky little bastard and sometimes you may have to un bolt your fuse box to find it.
i highly doubt your missing it.
Old Sep 2, 2009 | 10:08 PM
EvilPhu's Avatar
that wire is behind the fuse block, I just look for it today myself, installing fog light too. Get in a good position(your back on floor mat), and look behind the fuse block, look for a blue tape/brown plug like the link i send.
Old Sep 2, 2009 | 10:17 PM
DOMAN!EJ8's Avatar
oh ok, ill go take a peek tomorrow, and hopefully i find that "bastard" lol
DOMAN!EJ8's Avatar
but am i hooking it up correctly?
BbOi0420
Dec 12, 2014 04:40 PM
honda06si
Honda Civic (2006 - 2015)
Oct 9, 2006 12:48 PM
ekay. jay
Apr 23, 2006 06:13 PM
OEM_ASSASSIN
Sep 25, 2005 01:23 AM
ShakesTheKlown
Mar 29, 2004 09:19 AM
