Help with valve lash
Old Aug 26, 2009 | 03:50 PM
91EF919's Avatar
Default Help with valve lash
I am putting my car back together from building my head. I have a B18b1 with a port and polished head, ferrea valve seals, guides, keepers, Crower Valves, TI retainers, dual springs, and got Crower 404's. I am doing the last cylinder for a valve lash and doing the last intake valve. I called BC for what feeler gauges i use they told me for intake-.006 exhaust-.008. I went to go slid the feeler gauge thru didn't go thru so i loosened the nut all the way and the .006 still doesn't fit??? Only feeler gauge that fits is the .0025. Can someone tell me whats the problem. All the other ones were just fine working with.
Old Aug 26, 2009 | 04:02 PM
dacrxguy's Avatar
Default Re: Help with valve lash
are you moving the cams when you are doing this
Old Aug 26, 2009 | 04:08 PM
91EF919's Avatar
what u mean moving the cams. I am doing each cylinder right and right with the tdc. Cylinder #2 is when cams are pointing towards the right.
Old Aug 26, 2009 | 04:39 PM
dacrxguy's Avatar
the camshaft need to be rotated so that the springs are both closed you need to rotate the cam after the a cylinder is adjusted to put the next valves where they are opened
Old Aug 26, 2009 | 04:51 PM
Gunmetal_B20_Hatch's Avatar
make sure that the valve is closed... please.
I sorta have a bad feeling about this...
Old Aug 26, 2009 | 05:19 PM
4drEF's Avatar
Keyboard Humorist
Just reading and going literal.
Loosen the nut and then back the screw out.
Assuming you are doing that, just clarification.
Old Aug 26, 2009 | 06:17 PM
91EF919's Avatar
Dont know what u mean but dont know if this will change anything i got adj, cam gears? Do you think they where put on the wrong way if there is a wrong way? And can u explain more about rotating the camshaft. I adjusted the timing so that 0 degrees is top dead center on the ex. side but its a little off on the intake side because of the advanced dizzy
Old Aug 26, 2009 | 06:35 PM
beansandrice's Avatar
Adjustable cam gears wont do anything to your valve lash.
Follow all the steps close.
http://www.c-speedracing.com/howto/v...alveadjust.php
Old Aug 26, 2009 | 08:24 PM
dacrxguy's Avatar
that is what i meant i am sorry i was not clear since i was in a rush
Old Aug 27, 2009 | 10:46 AM
91EF919's Avatar
if i rotate my cam then the cam gears wont match like the old ones for instance the 2 arrows needs to be pointing up if i rotate it then its not going to match right?
91EF919's Avatar
o and all the other rocker arms are fine its only one that is my problem
Old Aug 28, 2009 | 10:46 AM
91EF919's Avatar
yesterday i swapped rocker arms and it worked. Only thing is that it still doesn't fit the .006 now it can fit the .005 so i think that is good enough.
Old Aug 28, 2009 | 03:44 PM
Have you done Valve lash adjustments on hondas? Not trying to come across rough but you could F stuff up. Just be carefull. Follow those instructions I posted for you. If you cant bend a wrench or dont have an adjustable head wrench for the adjustment or you dont have this
I recommend taking her in.
Old Aug 28, 2009 | 05:25 PM
91EF919's Avatar
yea i think it should be fine its way better than .002. I am going to see what my tuner says about it. Thanks everybody
pentaq
Apr 19, 2006 01:51 PM
HondaGuy02
Jun 2, 2005 06:27 PM
JDM-TypeRteg
Jul 6, 2004 08:22 PM
