Old Mar 25, 2015, 09:16 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Anyone have any luck finding an internal distributor seal
Old Aug 26, 2009 | 03:46 PM
sublime423's Avatar
Default Anyone have any luck finding an internal distributor seal
for an 94 EX accord? I seem to be only able to find the non-vtec ones. Any help would help. Thanks
Old Aug 26, 2009 | 06:48 PM
jb.'s Avatar
jb.
Default Re: Anyone have any luck finding an internal distributor seal
try carquest or napa. Carquest had them in stock near me in Raleigh. You are talking about the one the size of a quarter that fits inside the motor area correct?
Old Aug 28, 2009 | 08:09 PM
sublime423's Avatar
Yeah that is the one but I can't find one for an EX they only offer them for the non-vtec engines. same with the Napa here in Dallas.
Old Aug 28, 2009 | 08:36 PM
TheEvilBain_TDB's Avatar
Have you tried Ebay Or summit racing or even a honda dealer ship? Also would it be listed as anything else? When I was getting tranny parts for my 5speed some parts were named diffrent.
Old Aug 29, 2009 | 12:12 PM
nicolaselias's Avatar
Loved
Community Favorite
I am having a similar issue with a leaking distributor but I cant find one to fit my tec distibutor...
I was wondering if this seal was standard for all model accords or is it based on your engine (vtec or non vtec) or is it based on dist. brand (hitachi or tec)
Old Nov 30, 2010 | 07:03 AM
teahtime's Avatar
If you are still out there, did you ever find the seal? I have a v6 with a similar problem and i'm curious if you were able to find the part.
thanks.
Old Nov 30, 2010 | 08:49 AM
GhostAccord's Avatar
If you are looking for the O-Ring that is located on the outside of the distributor shaft that seats inside the motor. The 98+ V6 part number is 30110-PC6-005, $2 at any Honda dealership.
Hitachi
90-93 - 30110-PA1-732
94-02 - 30110-PC6-005
TEC
90-02 - 30110-PA1-732
If your looking for the oil seal (inside the distributor) that is a little harder to come by. It can be found on ebay from time to time.
Manufacturer - NOK
Part Number - BH3888(E)
Old Nov 30, 2010 | 08:59 AM
redbull-1's Avatar
Manufacturer - NOK
teahtime has been posting in another thread on this and other forums. I am not sure if NOK BH3888(E) will fit the V6. Most listing do not include the V6 for that part. Ebay and a few other part sites have NOK BH3888(E) though.
One of the suggestion on another forum was to disassemble the distributor, find the seal, measure ID, OD, and thickness and order a replacement. The mod on that forum found the seal at rocket seals online catalog for an Acura 2.5 TL that way.
Old Nov 30, 2010 | 09:21 AM
Here are the measurements for the NOK BH388(E) for reference.
OD - ID - Thickness
22.5mm x 12.5mm x 5.5mm
Old Nov 30, 2010 | 10:05 AM
chikin pickle's Avatar
Partstrain.com
Old Nov 30, 2010 | 11:09 AM
holmesnmanny's Avatar
http://www.partstrain.com/store/?PN=...universal:0%29
Old Nov 30, 2010 | 08:00 PM
teahtime's Avatar
Thanks to all for the info thus far. Especially Redbull who mentioned the V6 specificity. We (rather, my mechanic) removed the distributor seal today and the measurements are slightly off of what is listed above: OD =22mm; ID=12.43mm; thk=6.42mm. I found the part on partstrain (thanks homesnmanny), ebay, and a couple of other sites. As Redbull stated, the engines listed are all but the V6 and i'm thinking that that to swage a 22.5mm part into a 22mm "hole" would be be pretty tough. Just thought I'd give this update in case it helps someone else or in case anyone has any other suggestions:]
Old Dec 10, 2010 | 04:18 PM
teahtime's Avatar
One last post (for me) on this topic: rocket seals rocks! We called them and gave them the measurements we'd taken. We were really lucky they had something in stock we could use. It wasn't exact, but we decided it would work. And so far, things are working well. A point to note as well, is that the o-ring and distributor cap seal for the v6 seem to be not available except at the dealer and for what they are, they are relatively pricey. So if you are going to go through the trouble of replacing the inner seal, replace the other 2 seals as well. The expensive price at the dealer is not nearly as annoying after the effort to find the inner seal.
Old Dec 24, 2010 | 11:48 AM
bestpartsonline's Avatar
I have distributor seals here if you are interested...
http://www.bestpartsonline.com/servl...ive/Categories
Old Dec 24, 2010 | 11:53 AM
Are you an HT sponsor or are you spamming? You may want to look into becoming a site sponsor if you want to pimp your wares here!
Ebay is still cheaper! They ship the inner and outer seal for less than you are offering the one seal shipped.
Old Dec 24, 2010 | 11:58 AM
redbull-1's Avatar
I believe it is the latter.
Old Jan 16, 2011 | 12:47 AM
The reason why I made the post was because someone who found me told me that the seal was really hard to come by. And after reading this discussion, I just wanted to help.
Here's the link to ebay for the BH3888 seal (which i do not participate):
http://shop.ebay.com/i.html?_nkw=BH3....c0.m270.l1313
They only offer the OE version which is made of regular Nitrile / NBR (black).
I offer both the regular version and the high performance version made of Viton / FKM (brown).
Old Jan 16, 2011 | 04:50 AM
It's nice to know that there is another place to buy these seals. Most local machine shops will sell them as well. However, You are still advertising your parts without being an H-T sponsor. Which is against forum policy.
On another note, this high performance O-ring, what is high performance about it? Only differences that I see between the two are Viton has a higher temp rating (203°C vs 135°C) and a higher price. The higher temperature rating is not a bonus in this specific application. If your distributor gets up to 275°C I think you will have bigger problems.
I also noticed on that link you provided, with the parts list, that you use the same ref# for both the OEM and high temp part. Why is that?
Old Jan 16, 2011 | 05:18 AM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
I just ordered this seal from you and oddly enough here you are on HT. I will make sure to keep HT updated after I install mine, I just want to say his site was the cheapest I could find everywhere else I searched the price was 18 to 21 dollars.
I am assuming you're the individual I e-mailed because of my uncertainty of the item?. I also want to add his response was prompt to my emails because I was skeptical the part was the correct one.
I hope all goes well when the seal arrives because so far you have been informative and helpful, wouldn't want to ruin your Rep.
Old Jan 17, 2011 | 04:19 PM
I apologize but again I was just trying to help the people looking for the oil seal. In fact, from previous posts you have pointed out that "the oil seal (inside the distributor) that is a little harder to come by. It can be found on ebay from time to time. Manufacturer - NOK Part Number - BH3888(E)"
Regarding the VITON version and using the same OEM#: From my understanding, since the OE only makes the NBR version, I thought I would provide an alternative for those seeking the high temp version. Just to avoid any confusion, the part in question is the Oil Seal inside the distributor - not the O-Ring.
Old Jan 21, 2011 | 12:00 PM
Community Builder
I appreciate your prompt service but that seal only fits the F22b2 engine not the F22b1. If you recall I ordered it from you few days ago and tried installing it and it was too big.
Although It is my fault I don't recall giving you my engine code, nevertheless thanks for the service.
Old Jan 21, 2011 | 12:34 PM
What size is the F22B1 oil seal?
The NOK BH3888(E) is listed to fit pretty much all of the Honda distributors, with the exception of the V6's. Are you sure that you removed the old oil seal completely??????
Old Jan 21, 2011 | 12:57 PM
Community Builder
Yes, I removed it using a screwdriver and rubber mallet.
To measure it properly wouldn't I need a vernier caliper?
Here's another thing I had an old distributor laying around, so I figured I might have some luck, turns out it's the exact seal I ordered, btw the old dizzy was from f22b2 engine.
Old Jul 12, 2011 | 04:00 PM
ttcheung97's Avatar
I also bought from "bestpartsonline," and I'll see how it goes. I made sure I selected the "f22b1 and f23a1" application.
LPDude
Apr 20, 2019 07:02 AM
ZillaG
Apr 6, 2016 02:56 PM
Mike8ike
Aug 26, 2013 06:49 AM
Buffalo.Rider
Jun 4, 2012 04:13 PM
