which are the best camshafts to my b16a2
Old Aug 26, 2009 | 02:28 PM
botero_vti's Avatar
Default which are the best camshafts to my b16a2
HI, I WANT THE BEST CAMSHAFTS FOR MY VTI B16A2 BUT I WANT THAT AT MINIMUM RPM THE MOTOR WORK LIKE FROM FACTORY.... BUT AT HIGH RPM WORK LIKE A DEMON! THE PERFECT WIIL BE THAN BEFORE VTEC WORK THE SAME AS OEM CAMSHAFTS, AND AFTER THE VTEC WORK SO SO SO HARD....PLEASE SOMEONE THAT CAN HELP ME I REALLY THANK;S
Old Aug 26, 2009 | 02:59 PM
eM1<3's Avatar
Default Re: which are the best camshafts to my b16a2
I can barely even understand what you're trying to say..... I Hear skunk2 cams are pretty good. But i'm not sure if that will fall into what you want or not.
Old Aug 26, 2009 | 03:02 PM
turboteg90's Avatar
pm for noodz
Old Aug 26, 2009 | 03:10 PM
B16Drag's Avatar
Cut him some slack, hes from Colombia... meaning English may not be his first language.
Botero, try not to use CAPS on here.
In terms of camshafts, what are you planning to do? All motor? Stock? Turbocharged? I say just get the Type R camshafts... but if they are hard to come by GSR's will be just fine. Kind of hard to ask for "DEMON" power in a naturally aspirating 1.6L Honda motor.
Old Oct 2, 2009 | 10:33 AM
botero_vti's Avatar
thank u b16drag, i want all the motor internals stock except the camshafts and valve springs with titanium reteiners... i'm watching stage 2 cams, and I don't know witch is better in my engine, look what i;m watching> crower cams(9259 rpm), brian crower(8500rpm), blox(9100 rpm), all in stage 2/... please help me to decide,... I; don;t know witch one work better in my motor b16a2... thanks
Old Oct 2, 2009 | 10:40 AM
JDM_SOHC's Avatar
they all work for different applications... N/A, Turbo, Nitrous, etc... depending on what u want all depends on what cams are best for u...
Old Oct 2, 2009 | 10:42 AM
botero_vti's Avatar
all motor... aspirated street race
Old Oct 2, 2009 | 10:43 AM
Ass$nyper's Avatar
Pirate General...YARRRR
lmfao
get two t-rex cams for an ls1.
You'll be killing um kid
SiBlueEG6's Avatar
d16z6 cams
cinci00si
41
Mar 16, 2009 07:58 AM
96_cvc_ctr
11
Dec 2, 2007 10:11 PM
Civic97s
Jun 19, 2007 08:19 PM
JDM*Fiend
Jan 13, 2007 12:58 PM
b16sipsssh
Oct 30, 2001 12:33 PM
