Clogged injector
Old Aug 26, 2009 | 02:10 PM
Hammtheman's Avatar
Default Clogged injector
is there a way to tell if injectors are any good. i pulled a mpfi swap out of a junk car and i am not sure if the injectors are good is there a way to test them or tell.
Old Aug 26, 2009 | 02:28 PM
grog's Avatar
Default Re: Clogged injector
you could mail them to RC engineering or other companies for bench testing, but for you and me running them is the best method. unplug them one by one (the wiring) and listen for a change in the engine, it should run rougher, if it doesn't its bad.
Boostbuilds
May 16, 2013 06:23 PM
Luserkid
Engine Management and Tuning
May 21, 2012 06:00 PM
bigsnorlax
May 21, 2011 01:42 PM
busychild
Jul 28, 2004 09:43 PM
