B18 swap
Old Aug 26, 2009 | 01:57 PM
hatched91zc's Avatar
Default B18 swap
i wanna do a b18 swap in my 91 hatch but not sure what ill need and whats a good setup for it
Old Aug 26, 2009 | 02:14 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: B18 swap
you can search all over honda tech about that topic.
here is an old thread from when I first started on the topic.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/b18a-into-91-civic-si-pros-cons-1316878/
Old Aug 26, 2009 | 02:56 PM
alright thanks man
Old Aug 26, 2009 | 03:09 PM
betojr82's Avatar
you will need the following:
90-93 Integra axles or aftermarket b-series into ef
90-93 Integra shift linkage or a aftermarket one
90-93 Manual transmission rear t bracket.
pr4 ecu.
90-93 throttle cable
b-series into ef motormounts
Old Aug 26, 2009 | 03:13 PM
how long would you say it might take if you had to estimate
Old Aug 26, 2009 | 03:15 PM
ryanevansoh's Avatar
it really depends on the experience you have. if its your first time it will most likely take awhile
Old Aug 26, 2009 | 03:38 PM
it will be my first b18 i helped my friend put a b16 in his hatch
Old Aug 30, 2009 | 10:36 AM
freeagent's Avatar
helpin is alot differnt than doin it your self thats what ive learned...doin the same swap as well
Old Aug 30, 2009 | 11:36 AM
D16SiHatch's Avatar
first time i installed a b-series in my hatch i did it entirely on my own, which includes pulling the a6 and dropping in the b18. i completed that in about a day. i was on a deadline and didn't want to pay for 2 days of usage on the engine hoist. assuming you dont run into any trouble and nothing stupid comes up it shouldn't take you all that long to do. just depends on how prepared you are and what level of mechanical prowess you possess lol.
Old Aug 30, 2009 | 12:08 PM
freeagent's Avatar
^^what he said i didnt research enough either ra into alot of stopping pionts were i had to reresearch...so make sure you do that to
Old Aug 30, 2009 | 03:18 PM
oldschoollove's Avatar
not to take over this but as far as wire was need to be done my cars already has a mpfi swap ?
Old Aug 30, 2009 | 07:59 PM
freeagent's Avatar
depends on what you want obd0..obd1?? what is it right now? that would all help chassis motor a1 b1? little help here..
Old Aug 31, 2009 | 11:01 AM
JDM-KIDD's Avatar
how long will it take it all depends on the person... like my brothers first time it took him a day to unhook everything and pull the engine... than another day to drop it back in and bolt it all abck together and doo all that good stuff.... but he also already had a b series in there so yea... and his full day was from like 1 pm to like 9 when it started getten dark
Old Aug 31, 2009 | 07:29 PM
the car obd0 and i my go obd1 if i cant find a obd0 ecu
ox_22
Jul 16, 2012 10:07 PM
integrawow
May 28, 2007 06:04 AM
Uniquerootz
Apr 20, 2007 11:25 AM
error
Dec 28, 2005 02:54 PM
