What throttle cable to use in a 93 cx with a 96 B18B swap?
Old Aug 26, 2009 | 01:20 PM
1nsoman1ac's Avatar
Default What throttle cable to use in a 93 cx with a 96 B18B swap?
hello,
i have a 93 civic cx daily/project that ive been fixing up, and its got a 96 B18B swap in it. it feels like my throttle cable is sticking, and i want to replace it cuz it is very long and pretty beat up. so i was wondering which throttle cable i should buy so that it will fit the setup?
thanks,
inso
Old Aug 26, 2009 | 01:44 PM
1nsoman1ac's Avatar
Default Re: What throttle cable to use in a 93 cx with a 96 B18B swap?
bump
Old Aug 26, 2009 | 01:54 PM
94EG8's Avatar
Seagull Management
'94 - '01 Integra RS/LS/GS
Old Aug 26, 2009 | 02:08 PM
1nsoman1ac's Avatar
okay thANK you very much. all of those years will work? even on the 96ls? i kow the 96 ls is different from 94-95 ls engines
Old Aug 26, 2009 | 02:09 PM
www.megameet.org's Avatar
I would use a b16 del sol one, it is short.
Old Aug 26, 2009 | 02:11 PM
1nsoman1ac's Avatar
ugh. does anyone have any part numbers? id ont have any idea what imbuying or wich ones will work
Old Aug 26, 2009 | 02:23 PM
94EG8's Avatar
Seagull Management
'94 - '95 are OBD1, but as far as I know honda never changed the Intake manifold in a way that would affect the length of the throttle cable. If you want to be really safe order one for the year of the engine, or more specifically the intake manifold.
Urg. Match the throttle cable to the intake manifold being used.
Old Aug 26, 2009 | 02:28 PM
1nsoman1ac's Avatar
so what OBD is the 96 engine? and how do i match it to the intake manifold?
Last edited by 1nsoman1ac; Aug 26, 2009 at 02:42 PM. Reason: doesnt show what i wrote
Old Aug 26, 2009 | 04:43 PM
1nsoman1ac's Avatar
bump
Old Aug 26, 2009 | 04:47 PM
Gunmetal_B20_Hatch's Avatar
you can reuse your D-series cable if you make your own bracket. its not that hard.
Old Aug 26, 2009 | 05:20 PM
1nsoman1ac's Avatar
i bought the car with the engine swapped in already
okay well i think il place an order for the 96 ls then. are there any good websites to find this for cheap? esides ebay?
esean93's Avatar
no use a da integra throttle cable!trust me fits good!dont need to make ur own bracket the throttle cable is like 15 bucks on ebay.the 94-01 cable will be too long i think.
Old Aug 26, 2009 | 05:22 PM
esean93's Avatar
nothin wrong with ebay stuff btw.its oem and its a throttle cable,not much could be wrong with it unless its visually snapped
94EG8's Avatar
Seagull Management
OBD2A. By match it to the intake manifold I mean use the throttle cable meant for the year and engine the intake manifold came from. In your case order a throttle cable for a '96 LS Integra.
You sure can.
Old Aug 26, 2009 | 05:29 PM
1nsoman1ac's Avatar
i think the 96 cable is really long. it like wraps around my alternator housing and just always gets in the way of me trying to fix my idle issues.
what year DA? do u have a link to it on ebay?
You sure can.
okay. so im stuck betwen DA and 96 integra. one of the other things is on the firewall, the litle black plastic piece that sorta locks into the firwallitself, through which the throttle cable runs through, doesnt want to stay locked in, and always comes out of the firewall. which lets the bare throttle cable rub against the firwall metal. is ther any way to fix this?
Old Aug 26, 2009 | 05:35 PM
esean93's Avatar
i think that problem will go away with a new throttle cable.the cable is suppose to lock into place so the firewall doesnt have anything that could break i think.its most likely the cable
heres the link
http://cgi.ebay.com/ebaymotors/90-93...Q5fAccessories
Old Aug 26, 2009 | 05:37 PM
esean93's Avatar
this link is for a brand new one!btw da is 90-93 integra
http://cgi.ebay.com/ebaymotors/ACURA...Q5fAccessories
Old Aug 26, 2009 | 05:43 PM
1nsoman1ac's Avatar
cool thank you. would you happen to know anythign about idle issues? lol
Old Aug 26, 2009 | 05:51 PM
esean93's Avatar
lol np problem!hows it idling?could be vacuum,ecu,IAC valve...whats it doing?
Old Aug 26, 2009 | 06:04 PM
1nsoman1ac's Avatar
okay well ive posted this a thousand times and nothing is working. so here it goes. 93 civic cx with 96 b18b ls swap. the engine haness is a vtec one. i have a p28 ecu. the ecu harness is all spliced into...but that doesnt matter cuz it ran fine for 8 months. anyways....the code it throws is the vtec code (non vtec engine+vtec harness=CEL).
turn car on, idles at 1100-1200. when hot, idles at 1500. took my intake off, with car running, plug the iacv hole in the TB with my finger. nothign happens. unplug the plug for the iacv..nothign happens. unplug the tps plug. nothing happens. unplug MAP, car dies. restart car, cover TB with my palm. the car dies. very strong suck, and keeps the vacuum for a while after car is off..which tells me theres no vacuum leak. checked TPS, its .33volts closed throttle engine turned ON (II). (this is also with the throtle screw...the one below the throttle rotor thing..all the way out. so i turn the screw till tps reads .45 closed throttle. turn car on idles at 2200. now today, i drove it to work, and the throttle seemed to "stick". like id be sitting at red light, light turns gren, i let go of the clutch slowly and try to push pedal, but it gets stuck a little. almsot like if the throttel plate had glue on the edges and would glue shut every time i let go of gas. its not the pedal. thats why i want to replace cable. the cable is properly loose....about 1cm of play from center. i have no idea what else could be wrong. i think its the throtel body.
Old Aug 26, 2009 | 06:11 PM
esean93's Avatar
i think its the ecu.run a p75,u can run a p28 but it would have to be chiped,i dont know alot about how to make it work.stock p28 is a single cam ecu to it doesnt make any sense to run it.make sure its manual ecu btw.the car is throwing a vtec code because p28 is vtec ecu and ur ls is non vtec.im sure u know this but just to clarify.
Old Aug 26, 2009 | 06:13 PM
esean93's Avatar
if u think its the cable take it off and let it idle.
Old Aug 26, 2009 | 06:21 PM
1nsoman1ac's Avatar
wait what? the p28 is single cam? wtf
i did. same thing. i unhooked cable let it idle same thing. i even bought another iacv....but when i hooked that one up....i think its froma gsr, it idled at 2000 then dropped to about 1500 in 2 seconds and stayed there.
Old Aug 26, 2009 | 06:27 PM
esean93's Avatar
yeah p28 is single cam,its from a ex eg civic ahaha.u said it use to run fine with p28though so idk.lets just talk on the other thread.this is too confusing lol.
Trickturn
Mar 9, 2007 07:21 AM
hatchydude
Sep 6, 2006 08:02 PM
derekhh
Jun 22, 2006 09:14 AM
xEnderx
May 10, 2005 09:06 PM
IS3Fifty
12
Feb 26, 2003 03:14 PM
