B&M Fuel Pressure Gauge
Old Aug 26, 2002 | 12:12 PM
twincamrex's Avatar
Default B&M Fuel Pressure Gauge
On the fuel filter i currently have there are both fuel lines on top, instead of one fuel line on top and one on bottom. My question is, does the fuel pressure gauge mount on top, where the service bolt is, or does it mount where the banjo bolt currently is.
Sorry for the newbie question, thanks in advance.
Old Aug 26, 2002 | 12:15 PM
matt_sb2000's Avatar
Default Re: B&M Fuel Pressure Gauge (twincamrex)
The gauge should come with its own banjo bolt that replaces the stock one, and gives you the port for the gauge.
Old Aug 26, 2002 | 01:46 PM
Malgerus's Avatar
Default Re: B&M Fuel Pressure Gauge (matt_sb2000)
Exactly. The instructions tell you all that needs to be done. Easy job.
Old Aug 26, 2002 | 06:12 PM
photonjedi808's Avatar
don't forget to put teflon tape on the threads. Or else it will leak and may cause a fire
Old Aug 26, 2002 | 10:27 PM
Malgerus's Avatar
Default Re: B&M Fuel Pressure Gauge (photonjedi808)
fires are good
Old Aug 26, 2002 | 10:51 PM
twincamrex's Avatar
Default Re: B&M Fuel Pressure Gauge (89_Y_49)
Haha, thanks for the advice..
I got the new fuel filter, gauge and pressure regulator on with no problems, thanks for the help...
I have another question, does anyone know what the stock fuel pressure should be on a jdm b16??
thanks again
Old Aug 27, 2002 | 07:28 AM
HybridFiend's Avatar
Teflon tape sucks, anyway they are pipe threaded and don't need no stinkin tape, eh!
Old Aug 27, 2002 | 07:50 AM
fires are good
hahaha
Old Aug 27, 2002 | 08:22 AM
rex_boy's Avatar
I think like 40-43psi at least that what the manual for a B16A3 says. You can kinda fine tune this based on you mods if It runs a little rich lower the presure a little.
Old Aug 27, 2002 | 12:55 PM
twincamrex's Avatar
Default Re: B&M Fuel Pressure Gauge (rex_boy)
i know in the helms for the 88-91 si's it says the fuel pressure should be between 36-41psi so i figured it would be somewhere around there...
phelpsj2
Sep 16, 2011 06:35 AM
juanchoenuncrx
Apr 10, 2008 10:09 PM
Jayzeroone
Jun 20, 2005 06:11 PM
mike2016
Jul 3, 2001 01:01 PM
