Transmission & Drivetrain Gearboxes, Differentials, Clutches
Anyway to use my Quaife LSD from b16 in a GSR?
Old Aug 26, 2009 | 04:50 AM
str8JDMteggy's Avatar
Default Anyway to use my Quaife LSD from b16 in a GSR?
I recently blew up my b16 trans. I have a quaife lsd in it and was wondering if there was any sneaky way to use this in the gsr tranny i just bought. Id rather not have to buy a whole new LSD. Let me know.
Old Aug 26, 2009 | 06:31 AM
Honda Bull's Avatar
Default Re: Anyway to use my Quaife LSD from b16 in a GSR?
You'll need B16 diff bearings, ring gear and its matching countershaft. Provided all of these are still good from the B16 trans.
Old Aug 26, 2009 | 08:05 AM
Aquafina's Avatar
And a diff shim.
Old Aug 26, 2009 | 03:21 PM
i just put both the counter shaft and input shaft from the gsr in my b16 case with my b16 quaife and everything seems to be fine. You sure you have to use the B16 counter shaft?
Old Aug 26, 2009 | 04:20 PM
Aquafina's Avatar
No. They're the same. But mixing and matching used gears is not good. Gear set...
Old Aug 26, 2009 | 07:19 PM
Honda Bull's Avatar
Like Aquafina says, it's not the best to mix and match. Most of our transmissions (D, B, and H-series) have 60,000+ miles on them. Over time, gears wear into each other despite a thin layer of fluid typically coating them. Mix and match these wear patterns, and sometimes things don't always work so well.
Old Aug 26, 2009 | 08:31 PM
Just drove the car with no problems at all. I'm using my b16 case, b16 ring gear on the quaife, Gsr counter shaft and main shaft with Gsr gears. Shifts like butter couldn't be happier!
Old Aug 26, 2009 | 10:38 PM
Mista Bone's Avatar
D Tranny Guru
in for the report of tooth failure.
Might look something like this......
....or you might get lucky.
Old Aug 27, 2009 | 07:28 AM
^ what do you mean by that? Is something going to break?
Old Aug 27, 2009 | 07:38 AM
Aquafina's Avatar
Probably.
Old Aug 27, 2009 | 07:45 AM
Originally Posted by Aquafina
Probably.
Could you explain a little more please
Old Aug 27, 2009 | 08:12 AM
Aquafina's Avatar
Gear set. Gears wear with each other. In the case of a FD, its the ring gear and countershaft. Mix and match used gears and they will likely fail. Either like in the pic Bone posted or by shearing teeth.
Old Aug 27, 2009 | 08:16 AM
I gotcha so they reason people say to switch the counter shaft was only
because it has mated with the ring gear. So the b16 counter shaft is
identical to the Gsr
Old Aug 27, 2009 | 08:24 AM
Aquafina's Avatar
Double yes.
Old Aug 27, 2009 | 09:45 AM
Well well see how it works out. Both ring gears and both counter shafts looked mint with no pitting whatsoever
Old Aug 27, 2009 | 11:38 AM
Aquafina's Avatar
That doesn't matter. If there was pitting then that means its already failed and shouldn't be reused even with the matching gear.
Old Aug 27, 2009 | 12:48 PM
Well the car will be on 24.5in slicks launched at 8k so well see what happens
Old Aug 27, 2009 | 04:28 PM
Aquafina's Avatar
Definitely not a good idea. Torque and high shock loads only stress the problem more.
Old Aug 27, 2009 | 06:02 PM
Honda Bull's Avatar
Better make sure the trans fluid has EP additives... and lots of 'em.
Old Aug 28, 2009 | 07:11 AM
If it breaks it breaks, I didn't build the car to drive it easy
Old Aug 28, 2009 | 10:30 AM
Aquafina's Avatar
Then you definitely shouldn't have mixed and matched.
Whats that saying about doing it right the first time?
Old Nov 5, 2009 | 05:12 PM
hybrdthry911's Avatar
gears holding up strong here. another 10 second pass after this and an 11.0 pass before it with crappy spark plugs.
http://www.youtube.com/watch?v=6FVDrjlUA7g
Old Nov 5, 2009 | 07:21 PM
night's Avatar
i wouldn't expect an instant failure of any kind. or a matter of months. but the odds are something will go earlier than if it was all original.
and nice power :thumbsup:
SLIM NOTHING
30
Jan 25, 2011 11:42 AM
cibao2ner
Sep 13, 2010 11:01 PM
ACTION JACTION
Apr 15, 2009 01:54 PM
the.hamburglar
Oct 14, 2008 08:38 PM
