fuse
my radio doesnt work and the clock doesnt work
is it the fuse? if it is where is it?
is it under the dash on the left hand side?
if not wats the problem then???
1997 HONDA ACCORD
1997 HONDA ACCORD
Under the hood, check "small lights" or something like that. It's the same fuse for the clock, radio, and cig lighter. It may not be "small lights", but just check all the names that make sense. IIRC it's a 15amp.
did you check the sides of your panels i dont know wat yr you have but i'm thinking most of the interior stuff is on the inside not in the engine bay since i dont know wat yr and car it is just open your door and check the side of your panels there should be like a little handle thing to pull out the board that's covering it it'll be on both sides so check there
momstaxi
May 1, 2007 01:24 PM
d16z6hondacrx
Oct 17, 2005 04:36 PM
