RADIO?????
Old Aug 2, 2004 | 04:35 PM
1badda's Avatar
Default RADIO?????
K my radio does not work i have no clue what it is . i check fuses and they are all fine inside and out . What esle can it be also the clock and cigarette lighter dont work neither so what should i do ..
Old Aug 2, 2004 | 05:45 PM
1badda's Avatar
Default Re: RADIO????? (streetaccord)
how about a lil help here
Old Aug 2, 2004 | 05:48 PM
nimblecivic's Avatar
this is just basic stuff here, but try checkin' your grounds....more than that, make sure your radio's harness hasn't come loose.....if everything else works fine start eliminating things....plug/fuse/etc.....good luck
Old Aug 2, 2004 | 08:06 PM
1badda's Avatar
Default Re: RADIO????? (nimblecivic)
nned more help
Old Aug 2, 2004 | 08:10 PM
Fugeeu's Avatar
re-check the fuses. I beleive all those things are the same fuse. I'm too lazy to go look now. That's the only thing I can think of.
Old Aug 13, 2004 | 01:01 PM
1badda's Avatar
i rechecked every fuse three time and none are broken . And yes they are running all from the same fuse
Old Aug 13, 2004 | 01:02 PM
1badda's Avatar
really need help bad
Old Aug 13, 2004 | 01:20 PM
SprayinCX's Avatar
how did you check them? i have found out that sometimes the fuse will not look blown but is not making full contact. try using a multimeter to check them. then if everything there is good check the ones under the hood.
after that go for grounds.
then check the 12v wires going to the radio with that multimeter i was talking about and see if you are getting power to anything.
if you are getting power,grounds are good,fuses are making contact. then the last thing is Call the Honda shop and schedule a early morning appointment.
Old Aug 13, 2004 | 01:22 PM
Eyes Only's Avatar
Default Re: RADIO????? (SprayinCX)
go to the dealership
Old Aug 13, 2004 | 01:24 PM
Deemeetree's Avatar
Electrician
Default Re: RADIO????? (AJax AirLines)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJax AirLines &raquo;</TD></TR><TR><TD CLASS="quote">go to the dealership</TD></TR></TABLE>
That's got to be the worse advice ever. They're going to rip him a ner butthole.
Check the fuse under your hood. Mine blew after 2 of my wires came in contact with metal and blew the fuse.
Old Aug 13, 2004 | 07:15 PM
sceg's Avatar
there is a 7.5 amp fuse under the hood for the radio. check it
Old Aug 13, 2004 | 09:41 PM
Dengar's Avatar
Default Re: RADIO????? (sceg)
did you disconnect the battery lately? you could have reset the radio and need to input the security code.
Old Aug 13, 2004 | 10:14 PM
sceg's Avatar
Default Re: RADIO????? (Dengar)
radio would still power up and say "code" on the screen, no sound or anything though if that were the case
patrickg833
Dec 9, 2017 06:42 AM
superchi
Oct 26, 2008 03:49 PM
scorpio1472000
Nov 27, 2007 07:15 PM
Tuesdaynightfever
Apr 5, 2005 07:34 PM
HYBRIDHATCH92
Aug 25, 2002 04:18 PM
