civic acting funny
Old Aug 25, 2009 | 06:43 PM
patwitahonda's Avatar
Default civic acting funny
ok i have a b16a swap ef hatch and my starter went out and it sat for two weeks i started it up and it sounded funny and pushed the gas and it smelled funny plz help me
Old Aug 25, 2009 | 09:20 PM
frank_el_tanke's Avatar
Default Re: civic acting funny
need more info... 2 weeks isn't a problem.
Old Aug 26, 2009 | 05:11 AM
dephtone's Avatar
Yeah you need to explain what "sounded funny and "smelled funny" means...those are pretty vague descriptions.
Old Aug 26, 2009 | 04:58 PM
i can see alot of exhaust and its not cold out.
CEL is giving me code 4 for the MAP sensor.
The Fan doesn't go on at all
Old Aug 26, 2009 | 05:03 PM
Gunmetal_B20_Hatch's Avatar
MAP code will likely make it run very rich. I'd start by fixing your MAP problem.
Old Aug 26, 2009 | 05:16 PM
code 4 is crank position sensor.
Old Aug 26, 2009 | 05:40 PM
it blinks 2 long then 2 short.
so its a 4 right?
or do i count after the 1st?
Old Aug 26, 2009 | 07:54 PM
ok, its code 22, vtec pressure switch sensor.i see no problems in the wires, but vtec doesn't pull so hard i think, not sure because haven't driven it in two weeks.
should i go to the junkyard and get one.if so can I use any vtec switch sensor?
Old Aug 27, 2009 | 05:08 AM
dephtone's Avatar
Is the pressure switch hooked up? Without the pressure switch, VTEC will not engage at all.
Old Aug 27, 2009 | 07:34 AM
as far as i can see the wires are perfectly fine.
i didn't move/touch it at all.
would a cluster swap have anything to do with it?
how often do the the sensors go out?
Old Aug 27, 2009 | 07:37 AM
dephtone's Avatar
I'v never seen a pressure switch go out before but I am sure it is possible.
Have you pulled the hazard fuse for 10 secs to see if the code is just stored in the ECU?
Old Aug 27, 2009 | 08:51 AM
can you tell me where the hazard fuse is located please.its a 91 si.
Old Aug 27, 2009 | 10:55 AM
located in your fuse box under the hood near the passenger shock tower. it's the 10 Amp fuse closest to the fender.
Old Aug 27, 2009 | 01:47 PM
ok my vtec wont engauge
fan wont turn on
ecu is giving me a code 22
Old Aug 29, 2009 | 12:17 PM
samelch7's Avatar
Had same problem dude what U probably did was connect the radiator temperature sensor thats locate near the thermostat where the v-tec solenoid goes flip them around disconnect the battery to reset the computer and see if its still giving U the code
brandynEG
Jun 28, 2012 06:23 PM
MonKK
May 4, 2009 09:42 AM
hondaman156
Nov 12, 2006 06:11 PM
WickedWerx
Oct 28, 2004 07:02 PM
