Need Help bad idle
Old Aug 25, 2009 | 05:49 PM
SlickEJ8's Avatar
Default Need Help bad idle
im having a bad idle @ 1400rpm. 94 si/ z6
i found a video (not my car but im have the same problem).
Any help is great thanks in advance.
http://www.youtube.com/watch?v=BW0yfQU7gzU
Old Aug 25, 2009 | 09:00 PM
SlickEJ8's Avatar
Default Re: Need Help bad idle
Old Aug 25, 2009 | 09:05 PM
Former User's Avatar
99 EX?
Old Aug 25, 2009 | 09:11 PM
SlickEJ8's Avatar
nah 94 si/ z6
Old Aug 25, 2009 | 09:14 PM
Clean the FITV and bleed the cooling system.
Is the CEL on? Any codes?
Old Aug 25, 2009 | 09:15 PM
SlickEJ8's Avatar
codes iacv and iat. i thought they were switched. i check there not..
i took the motor out my freinds car had no problems before the swap.
Old Aug 25, 2009 | 09:21 PM
SlickEJ8's Avatar
i think its the 02 sensor. its plugged in but its on the down pipe and the exhaust is not hooked up could that be it?
Old Aug 25, 2009 | 09:22 PM
If you reset the ECU, do both codes return when the engine is run?
What color wires are attached to the IACV versus IAT?
Old Aug 25, 2009 | 09:24 PM
SlickEJ8's Avatar
codes come back on after reset
iacv yellow/blk and green/white
iat red/yellow and green white
Old Aug 25, 2009 | 09:29 PM
What happens to the idle problem if you unplug the IACV?
What happens to the idle problem if you remove the intake and use your finger to block the port in the throttle body leading to the FITV?
Old Aug 25, 2009 | 09:31 PM
Have you tried cleaning the IAT and IACV?
Old Aug 25, 2009 | 09:32 PM
eyehategod666's Avatar
ttt
Old Aug 25, 2009 | 09:33 PM
What happens to the idle problem if you unplug the O2 sensor?
Old Aug 25, 2009 | 09:36 PM
SlickEJ8's Avatar
if i un plug the IACV it has the surging idle
for the FITV i will test that tomorrow its 12:35 and my neighbors dont like me already lol.
i also will bleed/flush the coolant.
Old Aug 25, 2009 | 09:37 PM
SlickEJ8's Avatar
nothing same thing happens
Old Aug 25, 2009 | 09:38 PM
SlickEJ8's Avatar
they were in good working order the day before the swap could that have changed?
Old Aug 25, 2009 | 09:45 PM
If you think the sensors are fine, then you need next to troubleshoot the wires.
Old Aug 25, 2009 | 09:48 PM
Definitely clean the FITV.
SlickEJ8's Avatar
i will get the guys harness i got the motor off and see what happens ill keep you posted
SlickEJ8's Avatar
ill try this first
Old Aug 25, 2009 | 09:49 PM
The O2 sensor is unlikely to be contributing, though the way it is set up, your gas mileage must suck.
Old Aug 25, 2009 | 09:50 PM
SlickEJ8's Avatar
haven't got to drive the car yet lol.... trying to figure stuff out
michaelsej1
18
Feb 21, 2011 07:13 AM
DelSol12345
Aug 19, 2008 06:43 AM
dsadas89das78934
Jan 15, 2004 08:01 AM
OneFastGsr
Oct 8, 2003 08:30 AM
slowdx
Sep 24, 2003 02:46 AM
