99 civic ex convert to obd1
I know this has been talked about time and time again but the threads I have seen give crap responses and are started by noobs.
Here is a run down of what I have and what I know I need:
I will be keeping my factory harness and running a conversion harness.
Obd1 GSR longblock.
Obd2 stock injectors.
Obd2 GSR distributor and alternator.
As far as electrical/sensor is that all that is required??
The only thing that gets me is the infamous Crank Position Sensor which is located near the crank pully on Obd2 cars.
What all is needed to be done to get this in properly. I have read the bypassing thread on FFS TechNet (Competition Clutch 0420) but want to make sure I have everything covered before I start the process. This is my first EK so I am new to Obd2
Obd1 GSR longblock.
However I just did a little more research, I was under the impression that the CFK sensor was needed untill I realized only obd2 ecus look for it so I am in the clear.
I plan to update the thread as a install guide for others and hopefully make it a sticky.
ok got everything figured out except for the distributor plugs!
I read around and apparently the 99-00 civic ex distributor plug is different than that of a 96-98 and 99-00 si distributor plugs.
Although they appear to be the same 10pin plug websites are saying they are different?
Is there any truth behind this?
http://www.xenocron.com/obd2-10pin-t...ter-p-439.html
NOman0608
Jul 26, 2007 10:28 AM
Civic98KH
Mar 11, 2007 09:21 PM
DetainedCivic
Apr 17, 2006 10:52 AM
9698, 99, civic, computer, conversion, converting, distributor, exs, gsr, harness, honda, obd, obd1, obd2, plug
