wiring up meh vtec
Old Aug 25, 2009 | 05:10 PM
trickster kid's Avatar
Default wiring up meh vtec
Ok, so I checked around the forums and found all kinds of helpful stuff. I've got a p28 and I pretty much know where to wire the solenoid into my ecu and how to do it.
My question is there are 2 prongs on the oil pressure switch side of the vtec solenoid. Do I wire both of them into a single wire to the ecu or do I ground 1 of them and send the other to the ecu? Does it matter which one I ground?
The solenoid wire part is pretty straight forward.
Old Aug 25, 2009 | 05:39 PM
Arthas's Avatar
Default Re: wiring up meh vtec
Ground one to chassis and send the other to the ECU.
The ground will be black. Ground that one.
Old Aug 25, 2009 | 05:52 PM
only thing black on this thing would be the solenoid plug so I ground that and the two tabs inside the oil pressure switch I send to the ecu?
tbgallant
Aug 16, 2013 10:41 PM
KiDDD...
Mar 27, 2012 06:11 PM
IVAN93EG
Jun 18, 2006 07:02 PM
EGB18C
Feb 2, 2006 02:57 PM
digital sol
Oct 30, 2004 12:07 PM
