Obd1 injectors on Obd2a integra?
So here's the deal, im putting my car back to stock (98 integra ls b18b1). Right now i have precision 525's with a benen fuel rail and fuelab FPR. My friend has a obd1 integra that he got for free and all he needs is the block so now i can get the parts i need. Could i take the oem fuel rail/injector/FPR from the obd1 car and put them in my obd2a car and it be fine with the obd2a p75? And if it does work, do i have to change the injector plugs back to stock or can i still use the ones i used on the Precision's?
To put obd1 injectors on obd2 injectors clips, i just shaved down the notch and everything was good. Yes the fuel rail and fpr should work also.
I don't have obd2 clips anymore, i'm not worried about the parts fitting I wanna know if the injectors are the same size and if they are saturated
