Does 1994 Del Sol D16 need new cat?
Hello all, and thank you beforehand for your help.
My 'Sol failed smog, and when I took it to a shop to have it diagnosed, the mechanic informed me that it needs a new catalytic converter, since the one currently on the car "is not lighting up." He mentioned that it is the same temperature at the front and at the back (I don't know how to interpret that). So, I just want to get the opinion of a few experienced members on these boards before I shell out the big bucks (broke college student). The car is completely stock with about 170K miles, so the diagnosis sounds about right. Anyways, the results of the emissions test are as follows:
744 RPM's (Low Speed):
HC: 237 (limit 180), CO: 0.51 (limit 1.20), CO2: 13.4 (No Limit Specified), O2: 0.00 (NLS)
2421 RPM's (High Speed):
HC: 105 (limit 180), CO: 0.92 (limit 1.20), CO2: 13.6 (NLS), O2: 8.61 (NLS)
As you can see, the problem is the Hydrocarbons at idle. The car was tuned up about 6 months ago (new cap, rotor, air filter, plugs). Oil changed about a month ago. The plug wires and fuel filter are a bit older (~18 months). Any advice?
Chevrille
19
Jun 3, 2013 03:52 PM
krisfnbz
Apr 1, 2012 10:31 AM
TallgeeseIV
Jul 7, 2010 12:32 PM
B18Redline
10
Jan 4, 2006 04:43 PM
