Skunk2 Megapower cat-back for 92-00 coupes, OBX Twin Loop muffler, misc exhaust parts
Old Aug 25, 2009 | 03:50 PM
94CivicSi's Avatar
Default Skunk2 Megapower cat-back for 92-00 coupes, OBX Twin Loop muffler, misc exhaust parts
I'm trying to clear out some of the misc. exhausts and parts I've got lying around.
Skunk2 Megapower Cat-back Exhaust - SOLD
I had this on my old hatch. Beautifully made muffler for the price and sounds great. 2.5" inlet. Note that I thought about painting this black, primed a small section on the bottom of the can, but then changed my mind. Never been welded on.
Hate to sell it, so it's going to take $50 to get it away from me.
cheap Magnaflow muffler
Had this on my Wife's VW as a temporary fix. It's literally the cheapest muffler that my local parts store had, but still $35. Galvanized construction, 2.25" center inlet, plenty of life left in it for your beater.
$10 if I have to meet you somewhere, $5 if you come get it.
used Magnaflow high flow OBD-2 cat
Not only is it some of the worst welding you've ever seen, this cat was run on a motor that burned oil and it will throw a code on an OBD2 car. You MIGHT be able to run it on an OBD1 car and plug the sensor hole, but no promises on your emissions inspection. Roll the dice, gut it, use it for the flange, I don't care. $5 and it's yours.
stock exhaust manifolds
(1) B18b1 - new compression gaskets where the pieces bolt together
(1) D16y8 - tried to tear it apart to see if I could make a B/D hybrid manifold and rounded off one of the bolts.
$20 takes either. There are at my Dad's house, so I need a day or two to access them.
Old Aug 26, 2009 | 07:57 AM
92egvx's Avatar
Default Re: Skunk2 Megapower cat-back for 92-00 coupes, OBX Twin Loop muffler, misc exhaust p
hey where u located
Old Aug 26, 2009 | 01:05 PM
94CivicSi's Avatar
I'm in Providence, RI, but I do a fair bit of driving around New England for work.
Old Aug 27, 2009 | 11:05 AM
94CivicSi's Avatar
back to the front.
Old Aug 29, 2009 | 04:28 AM
94CivicSi's Avatar
ttt
Old Aug 31, 2009 | 10:27 AM
94CivicSi's Avatar
ttt
Old Sep 2, 2009 | 02:49 PM
94CivicSi's Avatar
Skunk2 exhaust sold.
Old Sep 4, 2009 | 04:45 AM
94CivicSi's Avatar
Twin Loop pending @ $40.
T3T495GSR
Welding / Fabrication
Jan 19, 2008 11:53 AM
prostreetonline
Apr 4, 2006 12:13 PM
smooz EK
Nov 4, 2002 01:30 PM
