CEL Throwing Code 91, 53?
Hi, My CEL has been coming off and on recently, so I decided to jump the ecu for codes. I remember there was a post about the codes and stuff but I can't find it so decided to post on up for myself. Here's what happened, First it flashes 9 quick times then a pause then 1 flash. After that it flash 5 quick flashes then 3 slow flashes, So are the codes 91 and 53? What are the codes for 91 and 53 and how do I go on about fixing it. Thanks in advance
Kou,
Kou,
This is probably what you're looking for!
The new CEL thread (includes how-to and codes)
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Hope that helps!
Hope that helps!
