Tranny wont go in gear unless its jacked up
Old Aug 25, 2009 | 11:05 AM
d15bflat's Avatar
Default Tranny wont go in gear unless its jacked up
ok my tranny(88 si) ull go in gear when its not started and on the ground and when its not on the ground but when i start it on the ground wont go in gear..i jack it up and it goes in gear fine when its started wtf kind of **** is that
Old Aug 25, 2009 | 11:49 AM
d15bflat's Avatar
Default Re: Tranny wont go in gear unless its jacked up
bump please help
Old Aug 25, 2009 | 11:53 AM
4drEF's Avatar
Keyboard Humorist
Need more info.
Is this all stock or a swap?
Had you recently done any work to it?
Did this problem just start out of the blue or was it getting progressively worse?
Old Aug 25, 2009 | 11:54 AM
d15bflat's Avatar
no its a swap d15b with 88 si tranny and i just got the car starting and it only goes in gear when its turned on when its off the ground
Old Aug 25, 2009 | 11:55 AM
don foreman's Avatar
Diagnosing problems on the net has always been risky. Too many variables that are missed because your not there. So just trying to give you a guess (Mechanic for over 20 years). Sounds as if your having a clutch problem that's why it wont go into gear running, but seriously, it could be other things too.
Check your clutch cable for adjustment 1st and report back.
Old Aug 25, 2009 | 12:07 PM
4drEF's Avatar
Keyboard Humorist
What axles did you use?
Thinking you used the axles for the motor (rather than for an 88~91) and they are binding into the steering knuckle when you put it on the ground and the suspension gets the axles in place.
Old Aug 25, 2009 | 12:21 PM
d15bflat's Avatar
i was thinking it was binding 2 im not sure what axels cause they came with the swap i bought from a friend thats now in jail...and no way to talk to him but i figured since they fit in they would work
Old Aug 25, 2009 | 02:43 PM
4drEF's Avatar
Keyboard Humorist
I had binding problems twice with Z6 swaps using newer axles from the 92~95 car. They fit fine, but locked up from binding.
Some people don't have any problems with the newer axles so I really have no idea why they were binding on me, but the cars would not roll with those axles in.
I didn't try to spin the wheels in the air though... just assumed and tried the old axles and it worked fine.
IF you still have your old stock axles they should pop right in.
Old Aug 26, 2009 | 07:20 AM
d15bflat's Avatar
hmm kinda short on money but thatnks ill try it any one else ever had this problem?
Old Aug 26, 2009 | 08:47 AM
4drEF's Avatar
Keyboard Humorist
WtF was I thnking.
Nevermind my posts.
You can't even get it IN gear - not the axles.
I was thinking it was going in gear and not rolling.
Feeling like a crack head right now.
Old Aug 27, 2009 | 09:35 AM
d15bflat's Avatar
yea the only time it goes in gear is when its jacked up in the air
Old Aug 27, 2009 | 03:29 PM
0ne-Cam's Avatar
Check your rear mount(s) and the shifter linkage because it sounds like its getting cought somewhere when the car is on ground
Old Aug 27, 2009 | 04:40 PM
redflaredcrx90's Avatar
ok what clutch and fly wheel did you used 88 was a lone yr so make sure you have the right pp and disc. i have the same issue with my b16 swap . make sure your clutch cable is tight enough so that its engaging and disengaging
Old Aug 27, 2009 | 06:02 PM
mother ef-er's Avatar
i had the same exact problem youre having. this was about a year ago. i swapped a 88 si tranny into my 91 dx hatch. i dont remember the combo of pressure plate, clutch, flywheel and axles i used. i just know it took a while to get everything straight with it. everything is supposed to work if you have all the right parts and everything goes together fine.
my car was having the same problem you explained. i could get into gear with the car in the air and when the car was off.. but not while it was on. i couldnt find a damn thing for about a month on how to fix this problem. so i got my brother in law to push me with his atv down the road while i was in neutral. when i reached about 10 or 15 mph i slipped the car into first and popped the clutch, then feathered the gas. hahaha, everything worked out fine and my tranny shifts like a dream. now i dont reccomend doing this unless youre really fed up with the problem and absolutely cant find a reasonable solution.. and i had a spare dx tranny so i didnt mind if i f***** something up.
good luck man.. if you do find out exactly what the problem is post it here so we can see what is up with the transmission. and im not responsible for damages or injuries
Old Aug 27, 2009 | 07:37 PM
d15bflat's Avatar
thats what i like to hear ima do that exactly i have an extra 88 si tarnny and all the **** on it is from an 88 so ima try it
Old Aug 28, 2009 | 12:31 AM
jenifertom90's Avatar
there is some problem with your tranny....go and get it replaced or repaired.
Snailed EF
16
Oct 17, 2006 03:23 PM
wrXtian
Feb 10, 2005 02:22 PM
Escabar
22
Nov 7, 2003 09:49 AM
vtec69
Mar 28, 2003 09:15 PM
Mires
Sep 25, 2002 05:34 PM
