My 84 Prelude hesitates between 3500 and 5000 rpm. Any ideas?
Old Aug 26, 2002 | 11:00 AM
Elivi8's Avatar
Default My 84 Prelude hesitates between 3500 and 5000 rpm. Any ideas?
When it is cold and I step on it, it seems fine. That only happens once. After that it hesitates until about 4500, sometimes higher, sometimes lower and then takes off. Is it possibly my vacuum advance? or maybe my fuel mixture is too rich? It only happened recently before any mods were done.
Old Aug 26, 2002 | 11:57 AM
Daysleeper's Avatar
Default Re: My 84 Prelude hesitates between 3500 and 5000 rpm. Any ideas? (Elivi8)
Yeah...i have that problem to..do you have an carb engine??
Old Aug 26, 2002 | 12:04 PM
Elivi8's Avatar
Default Re: My 84 Prelude hesitates between 3500 and 5000 rpm. Any ideas? (Lude 3.gen)
yes its the dual Weihin carbs. I don't entirely think its the carbs though.
Old Aug 26, 2002 | 02:35 PM
doe's Avatar
doe
Any ideas?
get a new car?
sorry, I don't know what your exact problem is--I just felt like being a smartass
Old Aug 26, 2002 | 03:18 PM
RAB's Avatar
RAB
Default Re: My 84 Prelude hesitates between 3500 and 5000 rpm. Any ideas? (doe)
I got your solution. Your car is old
Old Aug 26, 2002 | 06:00 PM
4wsB21a's Avatar
New User
when was the last time it had a tune up? i had an 85 dual carb and i had to clean out the carbs (of course i had to take them apart, but hey) because there was dirt or something in one of them. i had a rough idle and couldn't seem to get anything out of the throttle when i tried to accelarate. after that i couldn't seem to get over 5000 rpms so i put in some bosch platinum +4's and i hit 6500 rpms like it was new. try a tune up and see what happens. (plugs, wires, cap, rotor, fuel filters)
Old Aug 26, 2002 | 11:48 PM
Missingsohc's Avatar
Default Re: My 84 Prelude hesitates between 3500 and 5000 rpm. Any ideas? (crlude)
the problem is your vacumme advance is getting stuck take your distributor apart and spray it with WD-40 and clean the termnals good get a new cap and rotor and either ngk wires or stock ones as any others will lead to problems in the future. email me at rtypeinertia@hotmail.com for a list of performance parts for that car.
P.S. Do not use Bosch platnum +4 on this motor as it can destroy it.
[Modified by JDMET-2, 3:52 AM 8/27/2002]
Old Aug 27, 2002 | 07:10 PM
4wsB21a's Avatar
New User
Default Re: My 84 Prelude hesitates between 3500 and 5000 rpm. Any ideas? (JDMET-2)
how do you figure the +4's can destroy that motor? just out of curiosity. the 85 that i had put them in over 6 months ago still runs just as good as it did when i first put them in it. and the owners of the car have put a lot of miles on that car in the last 6 months.
Old Aug 27, 2002 | 09:22 PM
PrecisionH23a's Avatar
Default Re: My 84 Prelude hesitates between 3500 and 5000 rpm. Any ideas? (RY8127)
HAHAHAHHAHA i was gonna post the same ****. lol
Old Aug 28, 2002 | 12:15 AM
they ruin the motor by creating to much spark scatter and they fowl out the cap way to easy. Plus it's all hype you spend to much for a low quality plug NGK-R's are the best for this car.
Zman1764
Aug 7, 2007 08:41 PM
nemesis6499
Jul 16, 2004 09:40 AM
TurnerDv1
Jul 27, 2003 12:37 PM
jkendall
Jul 20, 2003 09:50 AM
