DPFI To MPFI
i already did all the distro stuff, and i get spark, but i get no gas from the injectors
i've already got that they have no power, and im gunna recheck the wiring,
but that dpfi harness i used, had one less wire on the driver tower plug, then the harness that was in the car when we first pulled the motor.
but it looks like it came stock like that.
so is there different dpfi harness types or just ones with extra crap for other models?
ill take a pic and post it later just to help out.
i tried doing my swap this weekend i couldnt figure out the wiring cuz ur suppose to put the orange and white wires in the b10 and b12, there was a wire in b12 already then i dont get what ur suppose to do with the stock dx harness when i was using an si harness thats where i got lost
All the DPFI are the same, DPFI have 5 wires and MPFI have 7 wires at the firewall plug, the extra 2 on the MPFI are for the Cylinder Position Sensor.
You have to use the DPFI engine harness.
Unless I totally read that wrong.
#2 - Don't use the Si harness. It's a conversion of the stock DPFI harness to support the MPFI system and NOT a replacement or mix and match of DPFI harness with MPFI.
If the pic doesn't show it well, tell us what the color wire is that is missing and it's pin location as well as the color of the wire on the OTHER side of the connector when you plug it in (sometimes the wire colors are not the same on both sides of the connector.)
at the driver's side, the connector at the firewall for the 88 CRX Si is a rectangular 6-wire connector - all of the other MPFI harnesses have a round 8-wire connector - all of the DPFI harnesses have a round 14-wire connector - some of the DPFI harnesses have more or less actual wires in the connector, depending on whether the harness is from a a car with manual transmission or with automatic transmission or equipped with EGR valve (automatic in Calif only)
i checked everthing out and itseems im only getting 8.3volts to the injectors and im using obd1 injectors
i dont have the resister box just wire straight to the two blk/yel dpfi wires in the engine harness
so do i have to use the obd0 injectors and resistor box which i can rewire quickly?
i dont have the obd0 injectors and resistor box i have the obd1 injectors but im only getting 8.4 volts when i crank the motor and doesn't need to be 12 volts for obd1 injectors
i checked all the wiring and its all done correclty an dall soldered and heat shirnked , so what could be causeing me to only get 8.4 volts?
ok so, i checked and rechecked and even redid the dpfi engine harness again
and found it to be the injectors, they are putting out 8.4 volts when i crank the motor
i thought obd1 used 12volts, so what could be wrong here?
i put the c1 and c2 wires to b10 and b12, and ran the new c1 and c2 to the distro
and a3 and a7 to injector 2 and 4
im trying to convert my dx to the si i have voth engine harnesses and im stuck every one has different ways to do this swap does anyone have a diagram of so hit me up with it if u can email it to me @aaranda_21@yahoo.com thanks
mike93eh2
Apr 23, 2008 06:13 PM
johnzm
May 31, 2004 11:49 AM
elmalouno
Apr 26, 2004 02:35 PM
