Suspension & Brakes Theory, alignment, spring rates....
Cutting springs - what do you say to this?
Old Aug 25, 2009 | 06:50 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Cutting springs - what do you say to this?
Old Aug 25, 2009 | 07:21 AM
MiniMeWanabe's Avatar
Default Re: Cutting springs - what do you say to this?
I did this to my CB7, i believe we cut 4 coils in the front and 5 in the back
handled curves like a champ,but was very bouncy id go with coilovers or lowering springs myself..
Old Aug 25, 2009 | 08:52 AM
Slo-mo's Avatar
i believe that when cutting springs you shouldnt go more then 2 coils(if that) ive seen many cars with 1/2-1 coil cut and they got exactly what there looking for as far as drop and ride quality thats not bouncy. the only thing i dont agree with in that article is using the torch to cut the spring. ive always been told/used a grinder and a cut off wheel
Old Aug 25, 2009 | 09:10 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Can Someone confirm that, to cut, we cut from the top coil? Looking to take only 1/2 coil cut.
Old Aug 25, 2009 | 09:20 AM
9000k's Avatar
New User
Just save your money and at worst just get some lowering springs and maybe new struts if you don't plan on doing coilovers.
Old Aug 25, 2009 | 09:48 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Thanks for your reply. I know all about that, and have lowered cars for many many year. I did not go into details exactly what I'm doing for a reason.
If someone can answer (confirm) my question above, I will appreciate it.
Old Aug 25, 2009 | 11:18 AM
Fo-Do Fanatic's Avatar
I believe you go from the bottom not the top. Every cut spring I've seen(including mine) are cut from the bottom.
Old Aug 25, 2009 | 11:50 AM
racebum's Avatar
you always cut from the non flat coil. normally a spring has one side that's less flat than the other. like a side that sits in the perch. you cut there. also don't use a frigin torch if you don't have to. a cut off wheel in an air die grinder works better since you don't add so much heat to the spring. it's also a cleaner cut
Old Aug 25, 2009 | 01:25 PM
TunerN00b's Avatar
Correct on cutting the non-flat coil side of the spring.
Do keep in mind that heating the spring (past a certain point) lowers the spring rate, which is the last thing you want when lowering a car. I would only ever cut with a cutoff wheel, and only in short bursts to keep temps down, but never with a torch.
Not that I would actually cut a spring for any car with lowering springs available, but it is a viable solution for an oddball car that has no aftermarket support.
zacheryleatherw
Suspension & Brakes
18
Jun 7, 2011 02:56 PM
JPerkMr954
Suspension & Brakes
Jan 18, 2011 01:10 PM
CLIPHSET
Suspension & Brakes
Sep 9, 2009 01:58 PM
akaplan12
Sep 16, 2006 01:03 PM
Hondasaurs
Apr 16, 2002 09:32 AM
