hf harness install in ex crx
Old Aug 25, 2009 | 05:15 AM
GSR-TRBO-DA's Avatar
Default hf harness install in ex crx
I have this car we installed in 88 crx full hf wire harness engine, dash, body harness still no fuel I have 12v at injectors and 6v at pump help. How is this possible?
Old Aug 25, 2009 | 05:24 AM
dephtone's Avatar
Default Re: hf harness install in ex crx
Pump/Sending Unit might be bad. I would check the wires at the Main Relay to see if you are getting 6 or 12v there.
Here are some diagrams to help you.
Was it giving you the same voltage with the old wire harness?
Old Aug 25, 2009 | 05:28 AM
no i don't think so, i ran the pump straight and it turns on fine but isn't the resistor box only supposed to allow 6v to the injectors and then 12v to the pump that is what is bothering me. i have been looking for a wire diagram with voltage readings but nothing.
Old Aug 25, 2009 | 05:29 AM
dephtone's Avatar
At the resistor box you should have +12v going into it, and about +5v coming out. Are you able to try another resistor box by chance?
Old Aug 25, 2009 | 05:36 AM
also the guy who started this also went 90-91 on everything instead of keeping it 88-89 and i have changed relays and i get 12v going in the relay but nothing coming out. i don't get all 3 clicks out of the relay.
Old Aug 25, 2009 | 05:38 AM
yeah tried other resistor box and still 12v are any of the red and black wires supposed to have power?
Old Aug 25, 2009 | 05:40 AM
dephtone's Avatar
The red wires supply the power to the injectors, the yel/blk is the constant 12v source. Measure the voltage before and after the resistor box
What kind of injectors do you have? Are you 100% sure they are obd0 injectors?
Old Aug 25, 2009 | 05:46 AM
12v before and 12v after and this guy just told me that they are obd0.
Old Aug 25, 2009 | 05:51 AM
dephtone's Avatar
Hum, do you happen to have another set of injectors that you DO know that are obd0?
Old Aug 25, 2009 | 05:57 AM
i don't think so, how can i have 12v on the yellow/black wire and then 12v on the red/black wires. it shouldn't make a difference if the resistor box is from a DA, or EF? would it?
turbohatchBnuts
11
Mar 9, 2011 05:53 PM
dc2_build
Jan 16, 2010 09:35 PM
GSR-TRBO-DA
Aug 21, 2009 09:43 PM
mugen_teg
Sep 6, 2006 04:19 PM
89 JDM CRX
Mar 29, 2004 06:50 AM
