New motor= won't run?
Old Aug 25, 2009 | 05:03 AM
Green Teggy's Avatar
Default New motor= won't run?
So i put a new motor in my car from hmotorsonline. I start it up and it runs great! It runs for about 2 mins and then shuts off. I turn the key and it fires right up and does the same exact thing.... Anybody have any suggestions?
Old Aug 25, 2009 | 06:04 AM
gonmaro's Avatar
Default Re: New motor= won't run?
reset your ecu? fuel pump or relay dying? bad ground?
Old Aug 25, 2009 | 07:18 AM
all above are good. Anybody think coil or distributor??
Old Aug 25, 2009 | 08:17 AM
Circusraven's Avatar
More likely than not, the coil would just quit on you and the car won't start. Is the timing right on the car?
Old Aug 25, 2009 | 08:48 AM
Yeah timing is perfect.
Old Aug 25, 2009 | 09:20 AM
stocker2shocker91's Avatar
I requested a short story for a title.
i would say there is probably a ground off somewhere. check around there is one that bolts onto the thermostat housing that get easily missed.
if the coil was bad it would not fire at all, and if there was something else wrong in the dizzy chances are you would have a cel.. Is the check engine light on?
Old Aug 25, 2009 | 11:33 AM
cel is on for o2 but i run a wideband instead... Car is boosted. Ive never had a problem with not running the o2 though. I'll check that ground but thanks for the suggestions
Old Aug 26, 2009 | 02:06 AM
up
makin1meand
Dec 10, 2008 05:00 PM
dan89crxsi
20
Jan 25, 2007 01:29 PM
tasco
Aug 18, 2006 12:18 PM
davidluko
Apr 9, 2006 12:35 AM
BOOSTEDgreeneg
Sep 15, 2005 07:27 PM
