Oil Pressure Tap Cracked
Old Aug 25, 2009 | 12:09 AM
B16Turtle's Avatar
Default Oil Pressure Tap Cracked
I was tapping in a new fitting to run an oil pressure gauge where the stock oil pressure sensor goes when it got fractured, I pulled the motor out and sent it to a machine shop to do an aluminum weld on it. I was just wondering if it will hold up on track or if i have something to worry about. Any advise would help. THANKS.
Turtle
Old Aug 25, 2009 | 03:38 AM
m R g S r's Avatar
Default Re: Oil Pressure Tap Cracked
You could have just drilled and tapped it to a bigger size, would have been easier than pulling the motor and sending it to a machine shop.
But why a machine shop to do the welding? Do you know if they do a lot of aluminum welding?
Old Aug 25, 2009 | 06:11 AM
hybrid_KJ's Avatar
I've done that before and it worked well. I had the port welded shut and then used a sandwich plate for oil feed.
davidayala831
Nov 24, 2017 10:59 AM
hotshot100
Apr 14, 2010 05:10 PM
accordfreak
Jan 26, 2004 06:14 PM
