1994 Honda Del Sol DOHC motor mount question
Old Aug 24, 2009 | 11:41 PM
xshortx's Avatar
Default 1994 Honda Del Sol DOHC motor mount question
I have the 94 del sol that comes stock with the b16a3.
question is what motor mounts do i get for it?
Do i get the one that fits b series into eg or the ek?
one of mine ripped out from the ac and looking to replace all of it since its
getting old and taking alot of abuse.
Thanks ahead
Old Aug 25, 2009 | 01:59 AM
94EG8's Avatar
Seagull Management
Default Re: 1994 Honda Del Sol DOHC motor mount question
'92 - '95 Civic.
Old Aug 25, 2009 | 10:30 AM
xshortx's Avatar
can i use any mounts that come from the 96-00 civic b16a2?
Old Aug 25, 2009 | 10:57 AM
GSaura's Avatar
I think you can use all of them except for the driver's side
Old Aug 25, 2009 | 12:22 PM
thumper64's Avatar
"Rick Rabies" has some I think, and he wasn't asking that much. PM him, he might still have some left.
Otherwise, you can fill old mounts with Window Weld to repair/stiffen then.
Old Aug 25, 2009 | 02:39 PM
94EG8's Avatar
Seagull Management
No.
Old Aug 25, 2009 | 09:51 PM
xshortx's Avatar
wut about mounts from 94-01 integra?
Old Aug 25, 2009 | 11:31 PM
Corksil's Avatar
xshortx - don't hijack...
OP = 92-95 civic ----- DOOOOO EEEEETTTT
Or you could get polyurethane ones from any internet vendor. Poly bushings = stiffer = better throttle response and torque...
POLYURETHANE FTW111!!
naw really....
hasport makes some nice mounts too, but I'm not sure they make polyurethane bushings so they are spongy and not as fast. Polyurethane bushings are harder then OEM ones, so you feel more vibration from the motor inside the car... Your *** is massaged more, so it's nice, and the girls like it too....
Old Aug 25, 2009 | 11:34 PM
Corksil's Avatar
EDIT
xshortx - sorry, you are the original poster - you're not hijacking. The advice still stands, most of it anyways... the rest is for the ppl trying to hijack threads.
everyone else - don't post drunk
Old Aug 26, 2009 | 08:08 PM
xshortx's Avatar
uh okay...
will integra gs-r mounts fit the my del sol that comes stock with the b16a3?
Old Aug 27, 2009 | 07:42 PM
xshortx's Avatar
bump for an answer
Old Aug 28, 2009 | 12:51 PM
xshortx's Avatar
still looking...
Old Aug 28, 2009 | 01:30 PM
nels00n's Avatar
you can use any mounts from eg dc and of course del sol...the only b series mount you can use of the ek is the rear tranny mount...hopes this info helps look it up yourself at www.hasport.com
Old Aug 28, 2009 | 03:50 PM
xshortx's Avatar
thanks alot, that helps
Old Aug 28, 2009 | 05:54 PM
94EG8's Avatar
Seagull Management
You can't use an EK T-bracket on a Del Sol. Must be Del Sol VTEC or '94 - '01 Integra. As far as the rubber mounts go Civic, Del Sol or Integra doesn't matter, except for the drivers side rubber engine mount, which must be a black stamped unit with 2 holes, not the aluminum 3 hole version found on Integras, VX hatchbacks and some EX/Si models, and the front lower mounts (the rubber parts) must come from a civic or del sol.
Old Aug 28, 2009 | 07:26 PM
nels00n's Avatar
learn how to read man i didnt say t-bracket i said ek rear tranny MOUNT..
Old Aug 28, 2009 | 08:36 PM
NV D Sol's Avatar
or if you only wana spend a couple bucks you can fill your stock ones with polyurathane window seal. thats what i did. take a few says to set tough.
Old Aug 29, 2009 | 02:08 AM
94EG8's Avatar
Seagull Management
Most people have a tendency to mean T bracket when they say rear mount. Either way you're wrong. Check the part numbers, '92 - '95 civic and '94 - '97 Del Sol Vtec (all del sol models actually) share the same part number. '96 - '00 civics are different.
Old Aug 29, 2009 | 11:04 AM
nels00n's Avatar
well tendency is not here i clearly said rear MOUNT and on a b-series swap the rear mount is interchangeable on eg dc del sol and ek..thants the only mount off a ek you can use. part # may not be the same as you say but they are interchangeable..my boy is using a eg hasport rear tranny mount on his ek hatch and i had a ek hasport rear tranny mount on my eg 4 dr..so if your trying to tell me it doesnt fit tell it to our cars
xChrizcrozzx
Aug 21, 2014 05:15 AM
j-villani
Sep 27, 2012 01:27 PM
busted240
Feb 3, 2008 09:38 PM
krc3104
Apr 11, 2005 03:32 PM
bluedelsol
Jun 3, 2003 06:14 PM
